Re: Which A833 is better race application, 307 or 308 case?
[Re: moparpoolman]
#2443423
01/30/18 02:39 PM
01/30/18 02:39 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
Are you racing a standard NP833 or the later O.D. version? If the O.D. tranny, that is the problem, those teeth are tiny on the cluster gear I've raced a lot of cars with the standard NP833, both the 23 spline and the Hemi 18 spline trans., at the track as well on the street, I've never heard of anyone breaking the gears like you are
[Re: moparpoolman]
#2443449
01/30/18 03:23 PM
01/30/18 03:23 PM
Posts: 3,096 Michigan
A727Tflite
What gear are you in when you do your burnouts? And what trans - OD unit or non- OD?
[Re: moparpoolman]
#2443472
01/30/18 03:42 PM
01/30/18 03:42 PM
Posts: 4,759 Moved to N.E. Tennessee
GomangoCuda
A heavy car with a violent clutch will find the weakest point in the drive train. You now know that third gear is that point in your car. If you are using a 70's technology clutch with high spring pressures and a grabby disk sell it now and get a light weight adjustable clutch from Hyatt, Advanced, or Boninfante. You will launch better and break less parts. Ignore this advice if you also drive on the street. EDIT:> I see that some people are using adjustable clutches on the street as well as strip. Just readjusting the base pressure. Hyatt Advanced
[Re: GomangoCuda]
#2444206
01/31/18 08:00 PM
01/31/18 08:00 PM
Posts: 4,457 Washington
madscientist
Washington
A heavy car with a violent clutch will find the weakest point in the drive train. You now know that third gear is that point in your car. If you are using a 70's technology clutch with high spring pressures and a grabby disk sell it now and get a light weight adjustable clutch from Hyatt, Advanced, or Boninfante. You will launch better and break less parts. Ignore this advice if you also drive on the street. ^^^^^^^^^^THIS^^^^^^^^^^^^^^^^^ You need a new clutch. There isn't a transmission you can buy that you won't break if the clutch is junk.
[Re: madscientist]
#2444234
01/31/18 09:05 PM
01/31/18 09:05 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I suspect you are breaking 23 spline transmissions but in any case 307 or 308 it doesn't matter. Your clutch is killing the gears like posted in the above replies. I have stripped third off of a few 23 spline boxes before I went to an 18 spline box and an adjustable pressure plate with bronze disc. You might be OK with an 18 spline unit at your horsepower level but as long as you are changing the clutch you might as well bite the bullet and invest in a good clutch. Be prepared though even an entry level clutch will cost you $800-$1000 for an adjustable unit Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: moparpoolman]
#2444342
01/31/18 11:24 PM
01/31/18 11:24 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
It's a standard NP833 non OD with a Hurst Super Comp. with a shorter (camaro) handle, 420hp to rear tire, 4.10 Dana with 28" slick. I also have a rev limiter set at 6000rpm. I Do Burnouts in 2nd. I am in deep trouble, then. Dan Brewer told me to lift between 2nd and 3rd or I will be replacing 3rd gear a lot.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#2444771
02/01/18 06:17 PM
02/01/18 06:17 PM
Posts: 356 NE
moparpoolman
NE
I've been following the thread in the race section about adjustable clutches like a McLeod Soft Lok, also they are talking about a "clutchtamer" anyone run a clutchtamer? I'm wondering what I should do with my centerforce clutch, switch to an adjustable clutch or maybe try a clutchtamer with it??? other thread in race sec. https://board.moparts.org/ubbthreads/ubbt...tml#Post2443277
[Re: Porter67]
#2444838
02/01/18 08:30 PM
02/01/18 08:30 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Just amazing???? Maybe I'm just the luckiest old fart here, or maybe it's something else? I've owned my Roadrunner since brandy new. 50 years of street driving and allot more racing since I'm retired. I've run 23 and 18 spline tranny's. I've used every type of clutch assembly over the years except for an adjustable type. I have NEVER broke a tranny. I currently run an 18 spline that is slick shifted with a Centerforce clutch. I've been running Centerforce for almost ten years. This is with a 3900# car with slicks at the track. The car makes over 600hp. Yah, I must be lucky??????????
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2444875
02/01/18 09:35 PM
02/01/18 09:35 PM
Porter67
And id bet your not launching at 6500 dead hooking, let me drive it and bring a 5 gallon bucket for old parts and a bag of floor dry for the track. Just amazing???? Maybe I'm just the luckiest old fart here, or maybe it's something else? I've owned my Roadrunner since brandy new. 50 years of street driving and allot more racing since I'm retired. I've run 23 and 18 spline tranny's. I've used every type of clutch assembly over the years except for an adjustable type. I have NEVER broke a tranny. I currently run an 18 spline that is slick shifted with a Centerforce clutch. I've been running Centerforce for almost ten years. This is with a 3900# car with slicks at the track. The car makes over 600hp. Yah, I must be lucky??????????
[Re: Porter67]
#2444879
02/01/18 09:47 PM
02/01/18 09:47 PM
68LAR
South Park, Pa.
And id bet your not launching at 6500 dead hooking, let me drive it and bring a 5 gallon bucket for old parts and a bag of floor dry for the track. Just amazing???? Maybe I'm just the luckiest old fart here, or maybe it's something else? I've owned my Roadrunner since brandy new. 50 years of street driving and allot more racing since I'm retired. I've run 23 and 18 spline tranny's. I've used every type of clutch assembly over the years except for an adjustable type. I have NEVER broke a tranny. I currently run an 18 spline that is slick shifted with a Centerforce clutch. I've been running Centerforce for almost ten years. This is with a 3900# car with slicks at the track. The car makes over 600hp. Yah, I must be lucky?????????? Nope no launching at 6500. I launch between 4900-5200 and DO NOT DEAD HOOK. EVERYONE knows, when racing, something has to slip. Automatic use the converter. Stick cars use the clutch or the slicks. I use the slicks. I don't want to be replacing a clutch every year. MY CHOICE. BUY the way, nobody drives my car except ME..
[Re: Porter67]
#2445154
02/02/18 12:43 PM
02/02/18 12:43 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
What are + and -'s of a mcleod duel disc clutch?
Hell Hath No Fury Like Mine
