Page 1 of 3 1 2 3
Soft Lok Clutch on the street #2443277
01/30/18 08:29 AM
01/30/18 08:29 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Any one run one on the street?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443287
01/30/18 09:42 AM
01/30/18 09:42 AM
Washington
madscientist Offline
Washington
Yes. Have been since 2004.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443288
01/30/18 09:52 AM
01/30/18 09:52 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If it's a preset pressure plate, it will probably be "Acceptable". If it is an adjustable plate, you have to dial it in for street use and track use. It can become a time consuming task.
[image][/image]
Re: Soft Lok Clutch on the street [Re: madscientist] #2443294
01/30/18 10:43 AM
01/30/18 10:43 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
What have been the disadvantages of street driving with that clutch?
I only go to the track a few times a year so if i need to adjust for on or off the track doesn't bother me. I have heard some people don't adjust and leave it the same pressure for both once they find a good pressure for there car does anyone have any input on that?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443312
01/30/18 11:43 AM
01/30/18 11:43 AM
Ohio
lockjaw-express Offline
Ohio
I have a McLeod Soflock set at 1200# and a Ram set for 1800#. That said the Ram 3 finger, 1800# base pressure with counter weights works better for the street, because of more base pressure.’
McLeod are not very helpful with setting up a soflok PP with heavier springs, as I had Hyatt Racing set one up for me. Also, the Soflok is 10.5” pressure Plate, and the Ram has 11” PP.
Overall, I like the Ram PP, and am using the McLeod Sintered Iron disc.
Mark
439FEAAF-D239-4F15-A7B3-1D6A40750DE0.jpegE8773F8C-B9CA-4F85-8376-CA61C4855A4B.jpeg159DBA48-BAD1-44E2-82D4-77EF1B47039C.jpeg
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443320
01/30/18 12:04 PM
01/30/18 12:04 PM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
Yes, I have run one on the street for five years. When I leave the track I add 3 turns of base pressure. I send it in every couple years and have it rebuilt.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443367
01/30/18 01:27 PM
01/30/18 01:27 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Thanks for the reply and pics, Seeing the pics helps a lot, I like the removable cover on the bell housing.
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2443369
01/30/18 01:29 PM
01/30/18 01:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mark
Did you add the window?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443374
01/30/18 01:40 PM
01/30/18 01:40 PM
Washington
Washington
Yes, you have to send the scatter shield in and have the window.
That's one of the disadvantages of the sintered iron disc. It needs to be adjusted. You also really need an adjustable pressure plate. When I stated using mine, I couldn't buy an adjustable plate, so I'd make 6-8 hard runs, pull the clutch and take it to a local friction house and have the pressure dropped.
I started at 1200 and ended up at 660 pounds with no counter weight.
I can't imagine needing 1800 pounds. Sounds like a parts breaker.
I update my clutch a few years ago. I now have an adjustable PP. On the street I use about 950 pounds of base and about 12 grams of CW to keep it from slipping. At the track, depending on conditions I start at about 500 and 10 grams of base and work from there.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443506
01/30/18 04:34 PM
01/30/18 04:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Can you use any disc or do you need something special?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443526
01/30/18 05:09 PM
01/30/18 05:09 PM
Ohio
Ohio
At 1000 HP, you will need the 1800 lbs with the sintered Iron disc, or you will glaze the hell out of the surfaces on the street. I use the Ram Long PP and 11”
The GTX has about 680 HP, and that one I have 1200 lb, and does in fact slip some on take off on the street, and it is the McLeod Soflok which is 10.5”
Both PP are counterweighted, and for the track I adjust both down to about 200 - 250 lbs via the access hole on the bottom of the Bell.
Madscientist is right, if you try to launch on the track with 1200-1800 lbs, they will be parts breakers.
Tim Hyatt (RIP) told me that you need 1200-1800 lbs of base pressure for the street, otherwise you will glaze up the flywheel and PP surfaces. He told me that his son Chris runs the higher base pressure for the street, and it works great.
I am by no means an expert, and just followed Tim Hyatt’s advice since he was the premier expert with clutches for high HP cars. Oh, BTW, both of my cars are around 3500 lbs...so pretty heavy!
Mark
Re: Soft Lok Clutch on the street [Re: cudaman1969] #2443532
01/30/18 05:18 PM
01/30/18 05:18 PM
Washington
Washington
It uses a sintered iron disc.
Re: Soft Lok Clutch on the street [Re: madscientist] #2443610
01/30/18 07:40 PM
01/30/18 07:40 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Where did you send the bell housing for the machining of the access plate??
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443627
01/30/18 08:05 PM
01/30/18 08:05 PM
Washington
Washington
Back to Lakewood. When I did mine it was 275.00 plus shipping.
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443673
01/30/18 09:29 PM
01/30/18 09:29 PM
Ohio
Ohio
I sent the Bellhousing to Hyatt Racing, as Lakewood did not want to do it.
Mark
Re: Soft Lok Clutch on the street [Re: lockjaw-express] #2443691
01/30/18 10:15 PM
01/30/18 10:15 PM
Washington
Washington
Mark
Is someone still working at Hyatt?
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443712
01/30/18 11:02 PM
01/30/18 11:02 PM
Ohio
Ohio
I really don’t know, I think Tim’s son Chris was moving to a small shop, but he may be just doing SFI Certs now...I do know that Chris will return your email, but I think he is just working part time.
I did not get a good feeling the last time I talked to Chris, so I bought my last custom clutch from RAM.
Mark
Re: Soft Lok Clutch on the street [Re: RATTRAP] #2443828
01/31/18 01:38 AM
01/31/18 01:38 AM
sgcuda Offline
sgcuda  Offline
As of the middle of last year, Chris was still adding windows and certifying bell housings. Pretty sure he is still doing clutch work, too.
[image][/image]
Re: Soft Lok Clutch on the street [Re: sgcuda] #2443878
01/31/18 02:47 AM
01/31/18 02:47 AM
Washington
Washington
Thanks. That's what I was asking.
Re: Soft Lok Clutch on the street [Re: madscientist] #2443882
01/31/18 03:01 AM
01/31/18 03:01 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I just received one of the two bells I sent to Hyatt. It's really, really nice and Chris is great to work with.
Not only did he add the window, the surfaced it to square it up. I was really impressed with that.
Page 1 of 3 1 2 3
