Stock replacement drive shaft source? #2442671
01/29/18 02:17 AM
01/29/18 02:17 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Trying to help out a local customer who needs to pick up a stock replacement quality drive shaft. His car is a 1970 Duster 340, 4 speed, stock 8.75 axle. He bought it without a drive shaft and needs a new one complete, nothing over the top OE, just a good street driver replacement. Any recommended sources?
Stock should be: #2883760 - 2.75 48.96" with 7260 U-Joints
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2442755
01/29/18 08:49 AM
01/29/18 08:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I got my driveshaft from Mancini as its a "Victory" driveshaft. Been in my 63 since 2006 and still looking good. But I had to give them a center to center U-joint cap measurement. I am more then pleased with that driveshaft. Ron
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2442799
01/29/18 11:38 AM
01/29/18 11:38 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
I would google replacement drive shaft....you would be amazed what comes up
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Stock replacement drive shaft source? [Re: yella71] #2442823
01/29/18 12:40 PM
01/29/18 12:40 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Check the "A Body parts for sale".
Member blewbyu has several that may work.
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2442874
01/29/18 02:34 PM
01/29/18 02:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might have a local drive shaft shop in your area.
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2442880
01/29/18 02:55 PM
01/29/18 02:55 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There's a shop in Post Falls on Seltice that's very good and reasonable; been happy with a couple he's done for me.
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2442945
01/29/18 04:55 PM
01/29/18 04:55 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Driveshaft Specialist of Texas, heard good things from them.
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2442984
01/29/18 06:21 PM
01/29/18 06:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks guys!
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2443040
01/29/18 08:08 PM
01/29/18 08:08 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'd go local... Pittsburgh Driveshaft made mine for under $200 and even installed my Moog bearings and Mark Williams forged yoke for free.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2443102
01/29/18 10:58 PM
01/29/18 10:58 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted By ScottSmith_Harms
Thanks guys!
Give Nick a call. There's a driveline service in Yakima that's really good.
Abe Lincoln
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2443303
01/30/18 11:15 AM
01/30/18 11:15 AM
an8sec70cuda Offline
If you have a local driveline or truck shop that makes them, just give em a call. They'll likely be cheaper than anyone you have to call and have it shipped to you. My local big truck shop has been making mine for the past several years and never had an issue w/ them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Stock replacement drive shaft source? [Re: an8sec70cuda] #2443310
01/30/18 11:31 AM
01/30/18 11:31 AM
NE
moparpoolman Offline
NE
I've used these guys, fast turnaround and reasonable
http://www.pstds.com/product-category/all-steel-shafts/
Re: Stock replacement drive shaft source? [Re: moparpoolman] #2443399
01/30/18 02:13 PM
01/30/18 02:13 PM
moparx Offline
moparx  Offline
i have found places that do big truck driveshafts somewhat a hit and miss when it comes to doing a car shaft. balancing is an issue because these shafts turn relatively slower than a car shaft, so they are balanced at whatever speed the truck place deems adequate for a big rig. secondly, truck shafts runout can be a lot more than a car and still be acceptable. it depends on several factors if you will, or can be, satisfied with a shaft from a truck place. myself, i would settle for nothing less than high speed balancing [two to three times faster than the truck places] and very minimal [.005-.008] runout in a driveshaft. that's just me. your results may vary.......
beer
Re: Stock replacement drive shaft source? [Re: ScottSmith_Harms] #2443469
01/30/18 03:41 PM
01/30/18 03:41 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
I've got a local place I use, usually just cut down a C-body one.
Rocket Restorations
Re: Stock replacement drive shaft source? [Re: tallzag] #2444243
01/31/18 09:22 PM
01/31/18 09:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Call Cass (doctordiff) he can hook you up with an awesome drive shaft at a reasonable cost twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Stock replacement drive shaft source? [Re: fourgearsavoy] #2444345
01/31/18 11:26 PM
01/31/18 11:26 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Gus beer
iagree I ordered my Strange driveshaft from him.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
