Edelbrock TR5 Small Block Tunnel Ram #2441731
01/27/18 10:04 PM
01/27/18 10:04 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Anyone ever use one with a single 4 top?
Re: Edelbrock TR5 Small Block Tunnel Ram [Re: STEFF] #2442776
01/29/18 11:04 AM
01/29/18 11:04 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Yes on a 30 over 360 with J heads ,holley 750 mech seconders, Hughes Mech cam, low .600 lift. ran that combo for about a month, then switched to dual 600s.
response was great , but 5/7/8 ran lean, till the 2 4bbl top was swapped
Re: Edelbrock TR5 Small Block Tunnel Ram [Re: STEFF] #2442838
01/29/18 01:01 PM
01/29/18 01:01 PM
STEFF Offline OP
STEFF  Offline OP
Thanx for the info. A buddy of mine has this thing sitting on a shelf and I was considering throwing it on my Sons Duster, to see how it reacts. He has the dual 4 top as well.
Re: Edelbrock TR5 Small Block Tunnel Ram [Re: STEFF] #2442913
01/29/18 03:52 PM
01/29/18 03:52 PM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
Use the dual top or don't do it at all...650 dp's are a dime a dozen and easy to rebuild.
Re: Edelbrock TR5 Small Block Tunnel Ram [Re: STEFF] #2442973
01/29/18 05:56 PM
01/29/18 05:56 PM
Washington
madscientist Offline
Washington
If it has the mail box top don't use that top. Call edelbrock and order the STR top for the SBC. It bolts right on, even though edelbrock says it won't. You don't need 15 gallons of plenum.
Re: Edelbrock TR5 Small Block Tunnel Ram [Re: madscientist] #2445519
02/03/18 08:57 AM
02/03/18 08:57 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Correct,or you might find a smallblock chevy edelbrock tunnelram with the smaller plenum at a swapmeet or in you local ads for even less.
