R3 dry sump prototype #2442362
01/28/18 06:37 PM
01/28/18 06:37 PM
MB,CAN
PC-CHARGER Offline OP
MB,CAN
New pan prototype in progress for Hvyweights R3!
My buddies are into wood! Lol!
Re: R3 dry sump prototype [Re: PC-CHARGER] #2442374
01/28/18 06:52 PM
01/28/18 06:52 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It's a lot cheeper to make a mistake with a piece of wood than aluminum. Looks good.
Re: R3 dry sump prototype [Re: PC-CHARGER] #2442375
01/28/18 06:54 PM
01/28/18 06:54 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I was going to send a link of
this post to Mike as I figured it would be something that would interest him.... and then I noticed where you are posting from 😀
A new iron curtain drawn across the 49th parallel
Re: R3 dry sump prototype [Re: 67autocross] #2442376
01/28/18 06:55 PM
01/28/18 06:55 PM
MB,CAN
MB,CAN
Actually Mike posted it from my address.
Re: R3 dry sump prototype [Re: PC-CHARGER] #2442394
01/28/18 07:30 PM
01/28/18 07:30 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Looks good.. be interesting to see how it turns out.. I don't think I would be afraid of trying it
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: R3 dry sump prototype [Re: PC-CHARGER] #2442705
01/29/18 03:42 AM
01/29/18 03:42 AM
rowin4 Offline
rowin4  Offline
I think the only trying will be for proper fit before the aluminum chips start flying
Re: R3 dry sump prototype [Re: rowin4] #2442846
01/29/18 01:13 PM
01/29/18 01:13 PM
MB,CAN
MB,CAN
Yep. Bigwedge is tapping a few holes in the wood and then it will be trial fit to the block in the car to check fitment and clearances. Mike has the aluminum already and once satisfied with the fit, the aluminum goes into the CNC.
Re: R3 dry sump prototype [Re: PC-CHARGER] #2442967
01/29/18 05:28 PM
01/29/18 05:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Never mind
Boffin Emeritus
Re: R3 dry sump prototype [Re: polyspheric] #2442991
01/29/18 06:37 PM
01/29/18 06:37 PM
MB,CAN
MB,CAN
Not exactly sure what you are asking but I suspect you mean how much air space above the oil line to the lowest point of the crank when the engine is running? What is not shown in the picture is the deflector/scraper that attaches to the passenger side of the skirting. This will have a five stage pump so each of the depressions in the lower pan will have a scavenge line.
Re: R3 dry sump prototype [Re: polyspheric] #2443043
01/29/18 08:18 PM
01/29/18 08:18 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
What do you mean by the "air volume"?
Re: R3 dry sump prototype [Re: Big Wedge] #2443062
01/29/18 09:00 PM
01/29/18 09:00 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Here we are cutting the pan section.
Re: R3 dry sump prototype [Re: Big Wedge] #2443307
01/30/18 11:26 AM
01/30/18 11:26 AM
CJD AUTOMOTIVE Offline
Is this something your planning on selling? I'd be interested.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: R3 dry sump prototype [Re: CJD AUTOMOTIVE] #2443477
01/30/18 03:53 PM
01/30/18 03:53 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Hi Craig,
I/we would most certainly be interested in selling these. This one is set up for a 340 R3 block with a front timing belt. What we have chosen to do is make a mock-up in MDF board to make sure the design works. Once we are satisfied with it, we are going to have one made out of aluminum.
Garth
