shrinker/stretcher ? #2439978
01/24/18 01:12 PM
01/24/18 01:12 PM
moparx Offline OP
moparx  Offline OP
just got a shrinker/stretcher to play with. specs call for use on 20ga. stainless, 18ga. steel, and 16ga. aluminum. as i need to put a gentle curve in a piece of 16ga. steel, i was wondering if i heated the lip before i fed it through, could that help the grippers of the tool work for this ? it is shrinking the lip. TIA.
beer
[note : i'm not a body man, and this does NOT need to come out perfect.]
Re: shrinker/stretcher ? [Re: moparx] #2440135
01/24/18 05:19 PM
01/24/18 05:19 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I know a guy who has one and you have to run the tool over it many passes to get what your after. It moves metal, but only in small amounts.
Not sure if warming it would help. Maybe annealing it with a torch to soften it up would be better?
Re: shrinker/stretcher ? [Re: moparx] #2440244
01/24/18 09:41 PM
01/24/18 09:41 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I wouldn't heat it.Practice on some scrap sheetmetal.
Re: shrinker/stretcher ? [Re: moparx] #2440474
01/25/18 11:48 AM
01/25/18 11:48 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
It will definitely be difficult to move 16 ga. with one. Just used mine last week on some used parts on a chimney project here at the shop. They can be real handy.
Re: shrinker/stretcher ? [Re: bbtrux] #2440483
01/25/18 12:09 PM
01/25/18 12:09 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
One of my next shop tools will be one of these shrinker/strechers for working with the sheet metal for the next Charger & the Road Runner.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: shrinker/stretcher ? [Re: moparx] #2440486
01/25/18 12:17 PM
01/25/18 12:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
If you bought a quality shrinker/stretcher, with quality jaws, 16 gauge steel shouldn't be a problem, only insert the mat'l halfway into the jaws depth, you'll find you can bump the mat'l better, I usually replace the handle with a longer piece, and fashion a handle grip using some heavy stock to give it some extra leverage and weight to help bump heavy stock or tight bends
Mike
Re: shrinker/stretcher ? [Re: DAYCLONA] #2440497
01/25/18 12:39 PM
01/25/18 12:39 PM
moparx Offline OP
moparx  Offline OP
thanks guys ! mike, i was thinking along your thoughts of making a longer handle. i will be doing a practice run with some scrap because i have never used these tools before. couple of things i will be keeping an eye on is the jaw teeth, and the tool's pivot points at the handle and body connection. didn't think about inserting the material only 1/2 way into the jaws. thanks for that tip ! anything else i need to be aware of ?
beer
Re: shrinker/stretcher ? [Re: moparx] #2440573
01/25/18 03:24 PM
01/25/18 03:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
A little WD-40 helps as well on the jaws
Re: shrinker/stretcher ? [Re: DAYCLONA] #2440973
01/26/18 01:36 PM
01/26/18 01:36 PM
moparx Offline OP
moparx  Offline OP
jaw teeth i assume ?
beer
Re: shrinker/stretcher ? [Re: moparx] #2441024
01/26/18 03:23 PM
01/26/18 03:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
I spray the jaw teeth and the lever mechanism, as well as the mat'l being bumped, helps reduce the friction/effort required
Re: shrinker/stretcher ? [Re: DAYCLONA] #2441459
01/27/18 01:31 PM
01/27/18 01:31 PM
moparx Offline OP
moparx  Offline OP
up thank you !
beer
Re: shrinker/stretcher ? [Re: DAYCLONA] #2442237
01/28/18 02:40 PM
01/28/18 02:40 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
A quality shrinker/stretcher would come from who? Eastwood maybe? I may buy one in the near future, and want a good one.
Re: shrinker/stretcher ? [Re: JDMopar] #2442281
01/28/18 04:06 PM
01/28/18 04:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes Eastwood, I have their dual combo unit shrinker and stretcher units so I don't have to change out the jaw sets, I mounted both units parallel, but opposite one another on a heavy duty stand so I can just switch the handle and go back and forth from one unit to the other to make immediate changes/correction in bumping the metal
I've purchased shrinker stretchers from HF and Woodward Garage in the past trying to be cheap, they were just ok to barely marginal... the jaws would either crack, or have a non existent grip right from the start, the Eastwood sets are a little bit more money, but worth the added expense for a better unit
mike
Re: shrinker/stretcher ? [Re: DAYCLONA] #2442539
01/28/18 11:26 PM
01/28/18 11:26 PM
JDMopar Offline
JDMopar  Offline
Thanks Mike. bow I try not to buy anything from Horrible Freight but silly widgets that I might use once every 10 years....lol.
Re: shrinker/stretcher ? [Re: JDMopar] #2442856
01/29/18 01:52 PM
01/29/18 01:52 PM
moparx Offline OP
moparx  Offline OP
i don't know the quality of the one i got [more than likely imported], but it weighs a ton, and the movement is very smooth. i have to get it mounted first before i try it, and i'm not sure when that will happen. i'm in the process now of getting "stuff" rearranged ["garage aerobics" biggrin] for new garage doors. i plan on mounting this on a piece of 5/8" plate that will have a 1 3/4", 1/4"wall square tube that will fit in the quick change pocket i built into the top of my heavy duty, moveable, work table. i mount quite a few tools to the table using this mount, including a vice, grinder, small tube bender, small solid round stock bender, etc. one of the best things to incorporate in a work table i have ever done ! holds tools very secure, and has access almost 360 degrees.
beer
Re: shrinker/stretcher ? [Re: moparx] #2442924
01/29/18 04:12 PM
01/29/18 04:12 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
So the Eastwood is the best bang for the buck & in quality over the Woodward, and of course over the Horror Freight Chinese junk?
Re: shrinker/stretcher ? [Re: moparx] #2445481
02/03/18 03:03 AM
02/03/18 03:03 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would think they all are the same.
