OEM Sat Radio (No Signal) #2442103
01/28/18 11:10 AM
01/28/18 11:10 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hi Guys, our daughters 08 Avengers radio says (No Signal), when trying to play Sirius radio. Where do I start, the antenna, radio, wires? Is there a common fix to this? Any advise would be appreciated. Thanks Scott.
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: OEM Sat Radio (No Signal) [Re: ScottG] #2442150
01/28/18 12:53 PM
01/28/18 12:53 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
This may seem like a smart aleck reply but it's not. I had this happen to my 15 Challenger. I had paid the subscription but Sirius hadn't turned my radio signal back on after receiving payment. I had to contact them. I also only get that message when my signal to antenna is blocked so I'd check the antenna next.
Terry
Re: OEM Sat Radio (No Signal) [Re: ScottG] #2442174
01/28/18 01:16 PM
01/28/18 01:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The preview channel should still work without a subscription.
Don't be the exception.
Re: OEM Sat Radio (No Signal) [Re: Supercuda] #2442180
01/28/18 01:24 PM
01/28/18 01:24 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Absolutely. If you are getting the preview channel and you have a valid subscription, this website will refresh the radio.
http://www.siriusxm.com/refresh
Re: OEM Sat Radio (No Signal) [Re: Supercuda] #2442182
01/28/18 01:25 PM
01/28/18 01:25 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
It was working for the last couple of months. The 184 Channel does not even work. It used to say (acquiring signal) when antenna was blocked, now it says (no signal). Thanks Scott.
