Throttle pressure lever stuck to shaft - really stuck
#2441778
01/27/18 11:05 PM
01/27/18 11:05 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Hey guys, long time no post - I mashed a header on a manhole cover and parked the car for awhile. Now I've got Doug's in and am in the process of dropping the valve body to get a mild B&M kit in and change the two shaft seals.
I have the selector lever completely loose - I can slide it up and down under the pressure lever. The pressure lever seems to be stuck to the top of the shaft - I have tried wedging and knocking a screwdriver against the underside of it after spraying yada yada, and it doesn't want to come off.
I'm wondering if I can just drop the valve body anyways and knock the lever off of the top of the shaft by bringing the entire VB down. Is there any other trick I can try?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Throttle pressure lever stuck to shaft - really stuck
[Re: Secret Chimp]
#2441779
01/27/18 11:06 PM
01/27/18 11:06 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
What car and trans?
And did you take the bolt all the way out? Or just loosen it?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Secret Chimp]
#2441793
01/27/18 11:16 PM
01/27/18 11:16 PM
Secret Chimp
Eugene, Oregon
Ah sorry I always do this here when I've been gone - small block 727 in a 67 Coronet. The pinch bolt is completely out.
[Re: Secret Chimp]
#2441799
01/27/18 11:31 PM
01/27/18 11:31 PM
amxautox
Maybe the edge is peened over some how, and is 'catching' the lever. The edge could be the top of the shaft, or even the edge of the half round 'hole' where the bolt goes thru/past. Just trying to visualize the parts and trying to think at the same time. You have of course pried the slot apart?
Tom
author unknown
[Re: Secret Chimp]
#2442553
01/28/18 11:57 PM
01/28/18 11:57 PM
Secret Chimp
Eugene, Oregon
I wasn't able to get a screwdriver into the pinch, I'd run the handle into the tunnel... luckily I was able to use the biggest flathead bit I could find and a hex wrench over the end. Even then, it took me 4-5 goes at what I thought was wedging against the pinch slot enough - finally popped it off after another good minute of dedicate wiggling. It's always little stupid things that eat up my hours! Thanks for helping me bark up the right tree.
[Re: Secret Chimp]
#2442566
01/29/18 12:12 AM
01/29/18 12:12 AM
amxautox
Good, ya got it. I'm use to trees with all the dogs I've had. lol
Tom
author unknown
[Re: Secret Chimp]
#2443073
01/29/18 09:27 PM
01/29/18 09:27 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's always little stupid things that eat up my hours! Thanks for helping me bark up the right tree. Well, at least you didn't call it the "kickdown" lever.
[Re: John_Kunkel]
#2443672
01/30/18 09:29 PM
01/30/18 09:29 PM
Secret Chimp
Eugene, Oregon
It's always little stupid things that eat up my hours! Thanks for helping me bark up the right tree. Well, at least you didn't call it the "kickdown" lever. I became versed in the linkage almost right after buying the car - the previous owner had left the return springs off of the linkage so it was shifting hard and late. I felt like I found hidden treasure when I set it up right and got that smooov 1-2 part throttle limo shift for the first time!
[Re: Secret Chimp]
#2443678
01/30/18 09:39 PM
01/30/18 09:39 PM
amxautox
The trans on my '76 Ramcharger wasn't shifting properly. Going uphill it wouldn't shift at all. Going downhill it would shift properly. Driving along on the level if I throttled up heavily, and backed off the throttle all the way, it would upshift. I even went to the Dodge dealer to see what it would cost to rebuild the trans. When I got home I checked it all out. Turns out the return spring was broken. Replaced it and all is well.
Tom
author unknown
