Re: 8.75 - Green Axle Bearing Question
[Re: ScottSmith_Harms]
#2441984
01/28/18 02:59 AM
01/28/18 02:59 AM
Posts: 16,158 Mesa, Arizona
dart4forte
Mesa, Arizona
I am swapping the stock axle bearings to green bearings in a stock 8.75 rear (741 case 3.91 sure grip).
Simple question.
Do I need to remove the stock thrust pin in the center section with the green bearings or just leave it there? Yes, just converted the GTS over several months ago.
Abe Lincoln
#2442052
01/28/18 04:20 AM
01/28/18 04:20 AM
dart4forte
Mesa, Arizona
Thanks for your input guys.....I just got an email from Cass (Dr.Diff) and he said I could leave them in. Now what? I guess it can't be a huge deal either way. I just got done taking them out and have the chunk bolted back in, I think I'll run it as is for now.
*Cass just emailed again, said its definitely ok to leave them out, just that leaving them in was ok too.
I had problems when I left them in the pig on my 64 Dart. I ended taking them out. but, who am I to arugue, Cass is the man when it comes to 8.75 rears. Going in the yellow car?
Abe Lincoln
#2442108
01/28/18 11:24 AM
01/28/18 11:24 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
you don't HAVE to remove the pin, but i would recommend it. on occasion the green bearing installation on the axle can locate the axle inwards a small amount, like 1/16". and with the pin still inside it can put constant outwards pressure on the green bearing causing early failure.
this happened to several people i know when green bearings first became available. they had constant bearing failures in a short amount of time until they removed the pin. after pin removal their problems disappeared.
perception is 90% of reality
#2442139
01/28/18 12:38 PM
01/28/18 12:38 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Mr T2U I think Cass does or did have a description of that exact problem on his site The early style (one piece design I think) is still available and moves the axles in too far. The newer style Cass has (two piece with snap ring I think) put the axles at the right depth to allow the thrust block to stay in. Important for Cone Type centers which require dissambly to remove the block.
May have the types mixed up, I just remember two types of green bearings. No doubt Cass already pointed the OP in the right direction there.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#2442333
01/28/18 05:40 PM
01/28/18 05:40 PM
Mr T2U
May have the types mixed up, I just remember two types of green bearings. No doubt Cass already pointed the OP in the right direction there. yes the green bearings my friends had problems with were the early design without snap rings. there are 2 different types. the early ones he used to sell then the good ones he sells now with the snap rings.
[Re: Mr T2U]
#2442417
01/28/18 08:29 PM
01/28/18 08:29 PM
Posts: 18,157 Mass
DAYCLONA
Mass
May have the types mixed up, I just remember two types of green bearings. No doubt Cass already pointed the OP in the right direction there. yes the green bearings my friends had problems with were the early design without snap rings. there are 2 different types. the early ones he used to sell then the good ones he sells now with the snap rings. Early style Green bearings are just as good as the "newer" style, just that in the past and present most of the installation instructions leave out the detail of removing the thrust button assy, which is there because of the original preload design, leaving it in can/could result in premature Green bearing failure as every axle and install has too many assembly variables to chance leaving them in, I put a set of the original Green Bearings perhaps 30 yrs or more in my Challenger T/A 8.75 rear with ZERO issues to date, every ride I build, customer's or my own toys get Green bearings, I've had ZERO failures with the Green bearings I've installed over the decades, proper installation is key to any components longevity... Mike
