91 5.2 L on head valve spring compressor what works ? #244167
03/05/09 04:08 PM
03/05/09 04:08 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Tryin to replace valve seals and my valve spring compressor (standard screw type) will not compress the spring enough to get the keepers out. Yes it's screwed all the way down the spring....What kind of spring compressor DOES work? Thanks
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 91 5.2 L on head valve spring compressor what works ? [Re: HemiRick] #244168
03/05/09 06:37 PM
03/05/09 06:37 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I was able to twist the spring down enough to get even the triple keepers out on the shaft style tbi motors. Those screw type compressors are at times obnoxious, but will work on most stock engines. You could try one of the hook under the shaft type tools I guess.
Re: 91 5.2 L on head valve spring compressor what works ? [Re: HemiRick] #244169
03/05/09 06:49 PM
03/05/09 06:49 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd use the Chevy lever type,all you need is a stud or bolt.
