Turn signal flasher question #2441294
01/27/18 12:24 AM
01/27/18 12:24 AM
NJ, USA
Kevlisa Offline OP
Kevlisa  Offline OP
NJ, USA
I found several turn signal flashers that might be correct for a 1970 B Body. Does anybody know which is correct? I found yellow stripe and green stripe units. It's going in a 70 road runner with hood mounted turn signals. Thanks.
Re: Turn signal flasher question [Re: Kevlisa] #2441412
01/27/18 10:41 AM
01/27/18 10:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just get one of the new style ones that is electronic.2 prong and install.I run them in my 65 and my 58 harley.Had problems with the old mechanical type.Either too fast or too slow.they work perfect.Rocky
Chrysler Firepower
Re: Turn signal flasher question [Re: therocks] #2441455
01/27/18 01:25 PM
01/27/18 01:25 PM
NJ, USA
Kevlisa Offline OP
Kevlisa  Offline OP
NJ, USA
Will do. Thanks.
Re: Turn signal flasher question [Re: Kevlisa] #2441487
01/27/18 02:13 PM
01/27/18 02:13 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I you are using original wiring and connector, you're fine,
if aftermarket wiring, i.e. Painless etc., be aware that the switch has polarity markings, don't remember why though....
Joe
