Undercut rocker studs
#2438620
01/21/18 08:55 PM
01/21/18 08:55 PM
Posts: 69 norcal
JLaSalle
norcal
Anyone know if ARP makes an undercut rocker stud for a big block, and what the part number is? I have some new rockers with thicker shafts and want to be sure I'm getting enough oil to the Rockers.
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
Re: Undercut rocker studs
[Re: JLaSalle]
#2439419
01/23/18 05:46 AM
01/23/18 05:46 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Anyone know if ARP makes an undercut rocker stud for a big block, and what the part number is? I have some new rockers with thicker shafts and want to be sure I'm getting enough oil to the Rockers. You did not say the brand, but the standard diameter sized rocker shaft should not have a problem. The T&D rockers uses a smaller than stock diameter shaft that is pretty thick to where the stud blocks oil flow. T&D supplies the kit with under cut studs. Because I did away with the stock rocker stands and used billet aluminum Max Wedge type rocker stand "blocks", I needed longer hold down studs that still needed to be under cut (except the bolts at the ends of the shafts.)
[Re: JLaSalle]
#2440604
01/25/18 04:23 PM
01/25/18 04:23 PM
Posts: 69 norcal
JLaSalle
norcal
Thanks guys,these are Mancini rockers made by Harland,so stock diameter shafts here.The shafts are considerably thicker than the cranes I am replacing which is why it got me to thinking about turned down studs,but from what some of you are saying,I may be overthinking it here,and the regular stud will be fine. I may in the future try to turn down these studs a little bit, or call T&D, but for now I'm crunched with time trying to make a race this Saturday,and will go beat on it the way it is!
