Re: shrinker/stretcher ?
[Re: bbtrux]
#2440483
01/25/18 12:09 PM
01/25/18 12:09 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
One of my next shop tools will be one of these shrinker/strechers for working with the sheet metal for the next Charger & the Road Runner.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: moparx]
#2440486
01/25/18 12:17 PM
01/25/18 12:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
just got a shrinker/stretcher to play with. specs call for use on 20ga. stainless, 18ga. steel, and 16ga. aluminum. as i need to put a gentle curve in a piece of 16ga. steel, i was wondering if i heated the lip before i fed it through, could that help the grippers of the tool work for this ? it is shrinking the lip. TIA. [note : i'm not a body man, and this does NOT need to come out perfect.] If you bought a quality shrinker/stretcher, with quality jaws, 16 gauge steel shouldn't be a problem, only insert the mat'l halfway into the jaws depth, you'll find you can bump the mat'l better, I usually replace the handle with a longer piece, and fashion a handle grip using some heavy stock to give it some extra leverage and weight to help bump heavy stock or tight bends Mike
[Re: JDMopar]
#2442281
01/28/18 04:06 PM
01/28/18 04:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
A quality shrinker/stretcher would come from who? Eastwood maybe? I may buy one in the near future, and want a good one. Yes Eastwood, I have their dual combo unit shrinker and stretcher units so I don't have to change out the jaw sets, I mounted both units parallel, but opposite one another on a heavy duty stand so I can just switch the handle and go back and forth from one unit to the other to make immediate changes/correction in bumping the metal I've purchased shrinker stretchers from HF and Woodward Garage in the past trying to be cheap, they were just ok to barely marginal... the jaws would either crack, or have a non existent grip right from the start, the Eastwood sets are a little bit more money, but worth the added expense for a better unit mike
[Re: JDMopar]
#2442856
01/29/18 01:52 PM
01/29/18 01:52 PM
Posts: 19,464 north of coder
moparx
i don't know the quality of the one i got [more than likely imported], but it weighs a ton, and the movement is very smooth. i have to get it mounted first before i try it, and i'm not sure when that will happen. i'm in the process now of getting "stuff" rearranged ["garage aerobics" ] for new garage doors. i plan on mounting this on a piece of 5/8" plate that will have a 1 3/4", 1/4"wall square tube that will fit in the quick change pocket i built into the top of my heavy duty, moveable, work table. i mount quite a few tools to the table using this mount, including a vice, grinder, small tube bender, small solid round stock bender, etc. one of the best things to incorporate in a work table i have ever done ! holds tools very secure, and has access almost 360 degrees.
[Re: moparx]
#2442924
01/29/18 04:12 PM
01/29/18 04:12 PM
6PKRTSE
Motor City
So the Eastwood is the best bang for the buck & in quality over the Woodward, and of course over the Horror Freight Chinese junk?
