Re: having a big problem need help! [Re: BigTerry] #2435282
01/15/18 11:03 PM
01/15/18 11:03 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
PB Blaster and a blue wrench, if you have the room. Otherwise smack it with a hammer a couple times.
Re: having a big problem need help! [Re: BigTerry] #2435336
01/16/18 12:24 AM
01/16/18 12:24 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I changed the pump in my 06 2500. I dropped the tank. I used a couple floor jacks and lowered it enough to disconnect the lines and wires. Then dropped it the rest of the way. My sending unit was cracked at the top and was throwing evap codes. Also I replaced the locking ring as it was so rusty it was toast. Not a easy job but not the worst I ever tackled.
Re: having a big problem need help! [Re: larrymopar360] #2439682
01/23/18 07:02 PM
01/23/18 07:02 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
thinking about cutting a door in the bed to get to the pump...
Re: having a big problem need help! [Re: BigTerry] #2439695
01/23/18 07:30 PM
01/23/18 07:30 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
There's really no need to do that, Terry. It was tough to get the bolts out of the bed of my 2001 Ram too. But whichever way you decide to go, stick with it and tough it out...you'll get it one.
Re: having a big problem need help! [Re: BigTerry] #2439697
01/23/18 07:36 PM
01/23/18 07:36 PM
P
Paul_Fancsali Offline
P
-Use a brass drift don't go smacking things that can spark By the way just ran into a stupid issue like that on a 2009 Journey it was the battery being below 12 volts Replaced the wheel well battery On a lousy day outside and all bolts were naturally rusted / frozen I have few choice words for the genius who made that design Starter sounded like it wanted to go but could not just whirred
Re: having a big problem need help! [Re: Fat_Mike] #2440256
01/24/18 10:16 PM
01/24/18 10:16 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
if I had a air impac gun it wouldn't be a problem to lift the bed
Re: having a big problem need help! [Re: BigTerry] #2440320
01/25/18 12:18 AM
01/25/18 12:18 AM
N.W. Florida
N.W. Florida
Is there enough room for a cheater bar on a 1/2" drive ratchet? What about a small ratchet strap on the end of the ratchet to get 'em broke loose? Let us know what you come up with...
Re: having a big problem need help! [Re: Fat_Mike] #2440514
01/25/18 01:10 PM
01/25/18 01:10 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
My father had a electric 1/2 dr impac gun i couldn't get them loose.. I spray the bolts with pb blaster.. I'm going to my friend shop this weekend if it don't rain he has air compressor. i got my finger cross if that don't work then we had to drop the tank. i really don't want to do that I'm not sure if he has a transmission jack.. I don't have the money to rent one either..
Re: having a big problem need help! [Re: BigTerry] #2446352
02/04/18 05:39 PM
02/04/18 05:39 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I'm happy to say I got my truck going again! i want to thank my best friend for helping me!! I don't know what I would done without his help!!
