Elephant ear, motor plate thickness #243952
03/05/09 11:46 AM
03/05/09 11:46 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
What is the minimum thickness a ear or plate should be? I need as thin as possible to avoid interference with my water pump and fan assembly.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Elephant ear, motor plate thickness [Re: Von] #243953
03/05/09 11:48 AM
03/05/09 11:48 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
1/4 inch, but make sure you put in good fore/aft limiter. we have done 1/4 inch no problem with 850-900 horsepower.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Elephant ear, motor plate thickness [Re: Von] #243954
03/05/09 11:48 AM
03/05/09 11:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
1/4"?
Re: Elephant ear, motor plate thickness [Re: Von] #243955
03/05/09 12:32 PM
03/05/09 12:32 PM
an8sec70cuda Offline
I have a 1/4" plate on mine w/ no problems. You can mill the back side of your water pump housing to offset the thickness of the plate if you need to. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Elephant ear, motor plate thickness [Re: an8sec70cuda] #243956
03/05/09 03:49 PM
03/05/09 03:49 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Once again, dang good info CHIP. That is exactly what I'll do.
Re: Elephant ear, motor plate thickness [Re: an8sec70cuda] #243957
03/06/09 12:13 PM
03/06/09 12:13 PM
NC
440Jim Offline
440Jim  Offline
NC
with Chip
Don't forget some type of fore-aft movement limiter.
Re: Elephant ear, motor plate thickness [Re: 440Jim] #243958
03/06/09 08:24 PM
03/06/09 08:24 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Not to Hi-Jack, but do you need for and aft locators if you run a midplate?
Re: Elephant ear, motor plate thickness [Re: joshking440] #243959
03/06/09 08:27 PM
03/06/09 08:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
YES definetly.
Re: Elephant ear, motor plate thickness [Re: Challenger 1] #243960
03/07/09 02:12 AM
03/07/09 02:12 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Do you need a limiter if you run a motor plate with a solid transmission mount?
Re: Elephant ear, motor plate thickness [Re: rowin4] #243961
03/07/09 02:41 AM
03/07/09 02:41 AM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
Depends do you like cracking tailshafts and trans cases? Cause I've always heard and been told a solid trans mount was a no no.
Granted I've seen a 9.40 hemi car run a front plate and poly trans mount and not break anything yet, but I wouldn't suggest that either.
