Cooling system issues #2439187
01/22/18 08:38 PM
01/22/18 08:38 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
What is causing this?Car sat for about 6 months.Should I get some sort of anode?
TIA
Re: Cooling system issues [Re: 5carguy] #2439225
01/22/18 10:00 PM
01/22/18 10:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yikes, looks like it was buried in a swamp. Not knowing what it looked like beforehand, looks like a leak at the hose at the very least. Those castings were pretty cheap & corrosion-prone to begin with, but I've seen plenty that are still OK after 20 years or so.
Re: Cooling system issues [Re: 5carguy] #2439325
01/23/18 01:20 AM
01/23/18 01:20 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I agree with a loose hose that has been leaking and moving around for a long time. Is the inside worn away as well? If the inside it pretty normal, the problem was caused by a hose problem. I've seen them worn before, but that one is about the worst I've seen. Gene
Re: Cooling system issues [Re: 5carguy] #2439327
01/23/18 01:23 AM
01/23/18 01:23 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Looks more like 6 years
Re: Cooling system issues [Re: 5carguy] #2439476
01/23/18 12:06 PM
01/23/18 12:06 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
This is not a leak problem but a corrosion problem.Any advice?
Re: Cooling system issues [Re: 5carguy] #2439481
01/23/18 12:21 PM
01/23/18 12:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Cooling system issues [Re: 5carguy] #2439500
01/23/18 01:05 PM
01/23/18 01:05 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
That does not look like electrolysis to me. That looks like acidic corrosion. Take a sample of the coolant to a big truck repair center. They should have the test strips to check for that kinda thing.
If that is what you are dealing with, there are neutralizers and such that will need to be used. And that thermostat housing won't be the only thing that needs attention.
Master, again and still
Re: Cooling system issues [Re: 5carguy] #2439549
01/23/18 02:20 PM
01/23/18 02:20 PM
BlueRacer69 Offline
BlueRacer69  Offline
What the heck is in the water you are using? You should be putting distilled water in your cooling system along with a good anti-freeze. Do a systems power flush and get that stuff out of your engine.
Re: Cooling system issues [Re: 5carguy] #2439789
01/23/18 11:30 PM
01/23/18 11:30 PM
Chicago
PurpleBeeper Offline
Chicago
Wow...I think I can help on this one.
1. I'm not there, but it does "look" like there was at least a little seepage from the upper radiator hose/clamp area. When that happens it almost looks like "battery terminal corrosion" & the outside of your thermostat looks that way to me in your picture. Antifreeze has corrosion inhibitors (anti-rust stuff) in it & a lot of those are white solids. When the water (& ethylene glycol) evaporate, the white solids are left. Just like if you dried out a glass of salt water & the salt is left in the glass. Corrosion inhibitors are salts too.
2. Seeing all that junk INSIDE the thermostat housing concerns me more. This "could" be "dried up anti-freeze corrosion inhibitor salts". Was your cooling system really low? I'm more inclined to agree with BlueRacer69. Did you use water out of your garden hose? "Hard Water" aka tap water & the worst is well water has a bunch of salts in it & they are not the kind of salts you want in your cooling system. Use distilled water or de-ionized water (about $1/gallon at Walgreens or grocery store).
3. I strongly suggest you flush your cooling system.
a. drain all coolant
b. fill with Prestone or other flush + distilled/de-ionized water. Make SURE you're outside temperature never drops below 32F while doing this since you won't have any "anti-freeze" protection.
c. drive the car for a whole day with the flush in it & make sure the engine gets fully warmed up & turn the heater on too. I would suggest you leave out the thermostat when doing this.
d. drain the water/flush
e. fill with just distilled/de-ionized water & drive at least 10-15 miles.
f. drain this water too.
g. fill your cooling system with fresh anti-freeze + distilled/deionized water (after installing your new thermostat)
h. for coolant, decent grade Peak Long Life (actually green Dex Cool) or Prestone yellow stuff works just fine. Use a decent brand & don't mix coolants of different types/brands.
4. If you want, you can check for "electrolysis" by searching online on U-tube or something like that. Basically, you will use an electric meter & measure current (or resistance? can't remember) with one meter electrode inside the coolant (radiator cap off) & the other end on the negative of the battery. I'm really fuzzy on this, so check what I'm telling you here. Electrolysis basically happens when stray voltage grounds itself THROUGH your coolant. I think the fix is to add an extra ground wire and/or clean your main battery/engine ground. Again, double check me on the electrolysis stuff.
Hope this helps!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
