Who makes a good aluminum straight vane B/RB water pump? #2436894
01/18/18 03:44 PM
01/18/18 03:44 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I was looking at going to a serpentine belt drive on the Imp but the 440 source water pump I got has a spiral vane impeller. That's a bit inefficient when the pump spins backwards.
Since the WP housing, cylinder heads, intake, and accessory brackets will be aluminum I thought I'd stick with an aluminum pump, too.
I had a Milodon years ago but it leaked from day one.
Any good leads for pumps that aren't needlessly expensive?
- Stu Harmon
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2436910
01/18/18 04:20 PM
01/18/18 04:20 PM
IL
furious70 Offline
furious70  Offline
IL
pretty sure you were on the thread here that pointed to this thread back then
http://www.dodgecharger.com/forum/index.php?topic=60599.175
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2436963
01/18/18 05:48 PM
01/18/18 05:48 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I remember that thread well. However, much time has elapsed and manufacturers enter and leave the game.
The pump flow was not the concern. I'm looking for an aluminum body and a straight vane impeller.
The spirally vane I have works fine until you spin it backwards. That's when it gets a bit sketchy.
- Stu Harmon
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2436970
01/18/18 06:05 PM
01/18/18 06:05 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
This is the one I use, never any issues but expensive as all MP parts are... eyes
JB Rhinehart, Realist
A-Body's RULE!
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2436983
01/18/18 06:25 PM
01/18/18 06:25 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
flowkooler. milodon is the brand we recommend in our kits. also summit racing makes or at least sells a generic version of the milodon hv unit with the anti cavitation plate that you need.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: Jerry] #2437296
01/19/18 02:38 AM
01/19/18 02:38 AM
that is an interesting thread. I would get an 8 blader & weld on the anticav plate with a 1.33 or more overdriven pulley & call it good. not sure what brand but after reading the thread I think a person could make an informed decision (just me I've had good luck with parts house rebuilts). & the rest of the cooling items correct, fan/shroud/spacer/radiator/stat/timing/mixture.
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: RapidRobert] #2437314
01/19/18 03:39 AM
01/19/18 03:39 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
This is the same pump Milodon uses, https://www.amazon.com/GMB-120-1200-Replacement-Water-Gasket/dp/B000P4WWXO just doesn't have the plate. Buy this pump and the plate and have the same setup for less then half the price. My dad runs this setup with his Reverse rotation serp. setup with no problems.
The only Carbs I care about are under the hood!
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: Azzkikrcuda] #2437351
01/19/18 09:41 AM
01/19/18 09:41 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Yeah the gmb or whatever it's called is What flowkooler attaches their plate to. They are made in Japan from what I remember. I've had both and was a little disappointed when I tried the gmb and realized that.
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: Azzkikrcuda] #2438996
01/22/18 02:26 PM
01/22/18 02:26 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Thanks for the info.
That is the aluminum housing, correct?
- Stu Harmon
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2439000
01/22/18 02:36 PM
01/22/18 02:36 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have the MP unit on my 440.Been there for close to 20 years.No problems and cools great.Rocky
Chrysler Firepower
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2439235
01/22/18 10:22 PM
01/22/18 10:22 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we also make an overdrive water pump pulley for those guys with cooling problems.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2439277
01/23/18 12:06 AM
01/23/18 12:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dude, you have an entire machine shop.
Don't be the exception.
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: Jerry] #2439289
01/23/18 12:24 AM
01/23/18 12:24 AM
BlueRacer69 Offline
BlueRacer69  Offline
Where can I find one of these overdrive water pump pulleys that you mention? Thanks.
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: feets] #2439377
01/23/18 03:03 AM
01/23/18 03:03 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
send me a PM or come pick one up at the shop in troy Mi.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: Supercuda] #2440521
01/25/18 01:27 PM
01/25/18 01:27 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Sadly, I have to balance life, job, and a disturbingly long list of projects. I'm only one man with very limited time.
Besides that, I have a full ground-up roadster build I need to get going.
- Stu Harmon
Re: Who makes a good aluminum straight vane B/RB water pump? [Re: Jerry] #2440527
01/25/18 01:32 PM
01/25/18 01:32 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Link to the pulley?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
