Launch opinion... videos... #2438574
01/21/18 07:54 PM
01/21/18 07:54 PM
Sao Paulo, Brazil
dart_73_br Offline OP
Sao Paulo, Brazil
Hello guys, could you please give me your opinion on my launch? Ladder bar setup. Using front adjustment on middle position. Can go higher or lower with the front of the bars.
Best 60" so far 1.92.
https://youtu.be/UsIxZMsaOr0
https://youtu.be/vrwt-bOzCAU
https://youtu.be/_IlviW1nVEI
1973 Brasilian Dart
E100, boosted 390"
Re: Launch opinion... videos... [Re: dart_73_br] #2438581
01/21/18 08:02 PM
01/21/18 08:02 PM
Washington
madscientist Offline
Washington
You need a two step.
You need more RPM on launch.
Front looks like it's doesn't have enough travel.
In the dark it's hard to see the tire but it looks like you need more rebound dampening.
What clutch are you using.
Re: Launch opinion... videos... [Re: dart_73_br] #2438597
01/21/18 08:28 PM
01/21/18 08:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It looks like the rear rebound is too loose. Slams the tire into the pavement and bounces back up.
Doug
Re: Launch opinion... videos... [Re: dart_73_br] #2438608
01/21/18 08:41 PM
01/21/18 08:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hard to tell much at all really to me. I see a ton of wheelspeed is about it, well and a lot of hopping. I noticed you start your burnout in the water, or well behind it with no smoke really at all. So I wonder one if you have an issue with water in the wheelwells Two tires are really not getting any heat at all if all the burouts are similar to that one. Three is the track prepped at all?
So here are some questions for you. What tire is on the car? DO you have a linelock? If you do what gear are you trying to do your burnout in? MOre info on the car like powerplant rear gear etc..
Re: Launch opinion... videos... [Re: Al_Alguire] #2438617
01/21/18 08:54 PM
01/21/18 08:54 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Thanks for the answers. Here more info:
318ci ~300hp on it. 4.88 gears. 3speed column shift.3300lbs Car. 28x9x15 old slick Hoosiers. E100 fuel. Ceramic clutch.
Launching on 3000rpm. Have option to enable two step of needed. Prepped track.
Next race will be different as I installed some progressive dry nitrous.150 shot going from 3000 50% - 5000 100%.
But still want to hear your opinion on the launch. Thanks.
1973 Brasilian Dart
E100, boosted 390"
Re: Launch opinion... videos... [Re: dart_73_br] #2438632
01/21/18 09:14 PM
01/21/18 09:14 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Needs tires
Re: Launch opinion... videos... [Re: dart_73_br] #2438652
01/21/18 09:40 PM
01/21/18 09:40 PM
Washington
Washington
Use the two step. You need to over rev the engine for the ROm drop on the three speed.
What clutch and what shocks?
Re: Launch opinion... videos... [Re: madscientist] #2438663
01/21/18 09:48 PM
01/21/18 09:48 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
You mean I ned to launch at a higher RPM ? i.e 4000rpm? ant his will drop to 3500 RPM?
Both are local brands.... single ceramic clutch. Shocks doesn't has adjustments. I think I need to upgrade to double adjustment ones right for having control over that bounce?
1973 Brasilian Dart
E100, boosted 390"
Re: Launch opinion... videos... [Re: dart_73_br] #2438682
01/21/18 10:06 PM
01/21/18 10:06 PM
Washington
Washington
IMO it needs to come out at a higher RPM. You could use double adjustable shocks. The clutch is what's going to be hard to control.
You also need to shift at a higher RPM because the spits are so big between the gears.
Re: Launch opinion... videos... [Re: dart_73_br] #2438777
01/22/18 12:02 AM
01/22/18 12:02 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You need a better burn out, and higher launch rpm. Try 3,500, then 4,000. What weight flywheel did you put in. If you already have a 30 lb. wheel, a rag disc will help soften the impact and let the engine stay at a slightly higher rpm. You don't have enough engine to require a ceramic clutch. I'm guessing once you get the launch rpm right, you will find out that you need the higher ladder bar setting. I didn't notice any real separation.
[image][/image]
Re: Launch opinion... videos... [Re: sgcuda] #2438793
01/22/18 12:36 AM
01/22/18 12:36 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Yes, it looks like it could use line lock (really bad), tires, shocks, and need some clutch slip. If the pressure plate is non-adjustable you might look at something like this:
http://clutchtamer.com/
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Launch opinion... videos... [Re: sgcuda] #2439223
01/22/18 09:53 PM
01/22/18 09:53 PM
Sao Paulo, Brazil
Sao Paulo, Brazil
Is it good to have the body separation? Heard that with ladder bars the car won't squat right?
1973 Brasilian Dart
E100, boosted 390"
Re: Launch opinion... videos... [Re: dart_73_br] #2439252
01/22/18 11:11 PM
01/22/18 11:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It looks like the rear bounced, spun and pulled to the right in the 1st video...........
Re: Launch opinion... videos... [Re: dart_73_br] #2439428
01/23/18 07:49 AM
01/23/18 07:49 AM
GravataĆ­, RS, Brazil
360tripleblack77 Offline
Hey Fernando, watching your videos looks like that shock rebound is too loose. Rear shocks can't keep tires planted at ground and that's causing tire bouncing. Maybe ceramic clutch can be another factor for cause this. As you said that you are using old tires, I would start changing tires for brand new tires like 28x10 or 28x10.5.
Good luck and keep us informed!
'77 Brazilian Dodge Charger R/T - Street Car
Footbrake, Pump Gas, SB Mopar 360" N/A
3300lbs, Leaf Spring + Assassin Bars
Best 1/8 mile ET
1.50 60' / 4.31 330' / 6.73@102.54mph
Re: Launch opinion... videos... [Re: 360tripleblack77] #2439436
01/23/18 09:02 AM
01/23/18 09:02 AM
Sao Paulo, Brazil
Sao Paulo, Brazil
Hello Diego, yes, looks like there are some consensus here. I need new tires 28x10.5 and some work with the rear shocks to solve that bounce. Additionally will work to change that 3speed to an automatic transmission. Loosing to much time between gear changes with this transmission....
Thanks for all imput guys! Will keep you informed on next passes...
1973 Brasilian Dart
E100, boosted 390"
Re: Launch opinion... videos... [Re: dart_73_br] #2439442
01/23/18 09:54 AM
01/23/18 09:54 AM
sgcuda Offline
sgcuda  Offline
A quicker change out would be upgrading to a 4 speed. You don't need a high dollar Hemi box. A normal 23 spline will be good for what you are trying to accomplish. Will probably bolt right in, too. I would have the gears and sliders slick shifted, or possibly lugged at Liberty to make your shifts quicker.
Re: Launch opinion... videos... [Re: dart_73_br] #2439505
01/23/18 01:14 PM
01/23/18 01:14 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
The root of your problem is clutch control. Hard hitting clutches require more shock control to prevent a bounce. If you soften the hit of that clutch, there's a good chance that you won't need you won't need new shocks or new tires. Add something like the ClutchTamer to control that hit and you will want to upgrade to a 4spd instead of an automatic.
