Head Gaskets #2438338
01/21/18 12:38 PM
01/21/18 12:38 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
When ordering head gaskets how should the bore size of the head gasket relate to the actual bore size of the motor? Like I have a 360 that's .030 over so its 4.03. Cometic makes a 4.04, 4.08, 4.125 and 4.18 gasket. Would the 4.04 be okay to use, or should I use the 4.08?
Re: Head Gaskets [Re: DusterKid] #2438406
01/21/18 02:26 PM
01/21/18 02:26 PM
I would probably choose the 4.125 or maybe 4.080 so the inside edges don't squeeze into the combustion chambers twocents work
Re: Head Gaskets [Re: DusterKid] #2438434
01/21/18 03:00 PM
01/21/18 03:00 PM
Keymar, MD
Keymar, MD
Will be using Edelbrock Performer RPM Heads. Seem they recommend the 4.18 gasket (As that's what Edelbrock headgasket is). I see Cometic sells basically 2 gaskets per compressed thickness. One has a note to be used with Edelbrcok Heads, so maybe its made differently for the Edelbrock heads?
Re: Head Gaskets [Re: DusterKid] #2438459
01/21/18 04:07 PM
01/21/18 04:07 PM
If Cometic has a 4.080" of the type they recommend for Eddy heads then that is what I would choose.
Re: Head Gaskets [Re: RapidRobert] #2438715
01/21/18 10:44 PM
01/21/18 10:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
may be 4.030 bore but how big is the chamfer at the top of the bore,you don't want the gasket to extend into the bore, some have way too big of a chamfer.
Re: Head Gaskets [Re: dartman366] #2438776
01/21/18 11:59 PM
01/21/18 11:59 PM
^^^ agreed, forgot about that.
Re: Head Gaskets [Re: DusterKid] #2438794
01/22/18 12:36 AM
01/22/18 12:36 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Question. How does the inner diameter of a steel circle get reduced by clamping load?
Re: Head Gaskets [Re: DusterKid] #2439008
01/22/18 02:48 PM
01/22/18 02:48 PM
Keymar, MD
Keymar, MD
I called Cometic today and the tech guy recommended the 4.080 gasket. Just curious if anyone with the Edelbrock heads have used this size?
Re: Head Gaskets [Re: DusterKid] #2439411
01/23/18 04:45 AM
01/23/18 04:45 AM
Edelbrock makes a bunch of different aluminum heads for the 318,340 and 360 motors, most are 65 CC but one or two are 63 CC chambers shruggy
