Removing paint from the dome light housing #2436538
01/17/18 08:39 PM
01/17/18 08:39 PM
robertop Offline OP
robertop  Offline OP
Many years ago I painted the dome light housing (69 roadrunner) with a paint matching the dome color. Now I would like to remove the paint, but there's a question: will a paint stripper remove the anodizing on the aluminum? Thank you for your answer, people.
Re: Removing paint from the dome light housing [Re: robertop] #2436540
01/17/18 08:46 PM
01/17/18 08:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it was a rattle can, I would try lacquer thinner on a rag first.
Re: Removing paint from the dome light housing [Re: Alaskan_TA] #2437709
01/19/18 10:59 PM
01/19/18 10:59 PM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
I agree
Re: Removing paint from the dome light housing [Re: robertop] #2437862
01/20/18 11:14 AM
01/20/18 11:14 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I would try Castrol Super Clean . its not near as harsh as lacquer thinner
Re: Removing paint from the dome light housing [Re: robertop] #2437870
01/20/18 11:43 AM
01/20/18 11:43 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Brake fluid works on plastic parts to remove paint. May work in this case.
Re: Removing paint from the dome light housing [Re: robertop] #2437873
01/20/18 11:54 AM
01/20/18 11:54 AM
Sudbury, ontario canada
750-h2 Offline
750-h2  Offline
Lacquer thinner on a soft rag. Will not hurt the anodized finish.
