ETC light ?? 2004 RAM #2437177
01/18/18 11:49 PM
01/18/18 11:49 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Question about my truck = 04 Ram , 5.7
The other day I went to start it to warm up. I let it run about 5 minutes and went out and it would idle high up to 2k for 10 seconds....then would go down to 500 for 10 seconds.....over and over.
A warning light came on and was flashing = ETC (electronic Throttle Control)
I shut it off for a few seconds and it started back up and its ran fine since.
The truck was outside for at least 24 hrs in -5 degree cold. Im assuming thats what caused it ?? It hasnt done it again.
If it happens again, what part do i need to replace or check ?
Re: ETC light ?? 2004 RAM [Re: 493_DART] #2437227
01/19/18 12:46 AM
01/19/18 12:46 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The Sun. You might want to squirt some carb cleaner in the throttle body to get rid of any grunge.
Re: ETC light ?? 2004 RAM [Re: 493_DART] #2437359
01/19/18 10:44 AM
01/19/18 10:44 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
That and test the battery.If its weak from cold the computer will do ceazy things.Best test is with a carbon pile tester lat actually loads the battery.Most places dont have them anymoe though.Rocky
Chrysler Firepower
Re: ETC light ?? 2004 RAM [Re: 493_DART] #2437645
01/19/18 08:26 PM
01/19/18 08:26 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
My 04 diesel runs the idle up when it's below a certain temp. It doesn't fluctuate though. You'll know when the TPS or ETC is going bad. Just keep driving it. Cold wreaks havoc on these things. I would be plugging it in at night if it was outside and I lived where the temp. was that cold.
Re: ETC light ?? 2004 RAM [Re: 493_DART] #2438286
01/21/18 05:54 AM
01/21/18 05:54 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok--thanks--hasnt done it since that day
