69 Road Runner Front Bucket Seat Hole Locations on Floor?
#2436929
01/18/18 04:46 PM
01/18/18 04:46 PM
Posts: 309 Dearborn, Michigan
gtxncuda
Dearborn, Michigan
Does anyone have the correct floor hole location measurements for the front buckets on a 69 Road Runner? I puchased the car last fall and the floor has been replaced at some point, and whomever installed the seats went a bit nuts with the drill, as I have two locations for each of the four (8) holes for driver and passenger seat. Both my seats 'look' wrong when viewed from the front as they tend to both lean toward each other. This makes for poor balance when going around corners and freeway on/off ramps. I removed the wonky brackets someone installed for more leg room, but now I want to get them planted properly in the correct location. If I get the correct measurement for the outside front and rear hole, the inners should follow suit. Can anyone help with some measurements? As always, any help is appreciated. Thanks!
1971 Cuda 340 auto 2013 Mustang Boss 302 L/S 1969 Road Runner RM21 440 4 speed
Re: 69 Road Runner Front Bucket Seat Hole Locations on Floor?
[Re: gtxncuda]
#2437002
01/18/18 06:51 PM
01/18/18 06:51 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Look from the underside. There are two brackets that attach to the inner rocker and follow the underside of the floor pan. There are holes that should line up with holes in the floor pan. Since you are going with buckets, there are usually two reinforcing plates that are welded to the floor pan. There should be dimples for those holes and the holes in the reinforcing plates should line up over them. You can see them in this photo I stole off the internet. I circled the brackets. This is a bucket seat car, you can see the inner studs and nuts too.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: 6bblgt]
#2437119
01/18/18 09:38 PM
01/18/18 09:38 PM
gtxncuda
Dearborn, Michigan
Thanks for the replies and the photos guys. Those definitely help. Admittedly, I have not removed the carpet yet, but the underside looks just like the internet photo shown, (even the sprayed on rustproofing) except I have TWO holes about 1.5" apart through the support bracket that goes toward the rocker. I'm going to measure both holes from the pinch flange, then compare to a friends 68 Charger R/T for reference. I assume the floor pans are similar for B bodies? (No Plymouth B bodies that I know of nearby to check...) Thanks again guys!
[Re: gtxncuda]
#2437406
01/19/18 12:44 PM
01/19/18 12:44 PM
Posts: 8,903 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The reason your seats lean towards each other is because you're probably missing the reinforcement plates for the inner bolts OR the large spaces haven't been installed. These would raise that side of these seats by about 1/2".
Also, the outer holes were different for bench and bucket cars. So if one of the owners had converted to buckets like I did, he would have had to drill the extra two holes. And I never realized those inner brackets existed for years so I drove around with my seats slightly tilted also !!
[Re: Stanton]
#2437410
01/19/18 12:50 PM
01/19/18 12:50 PM
gtxncuda
Dearborn, Michigan
Thanks for the info and the pic. Depending on which vendor used, I'm guessing some reproduction floor pans may not have the added supports? I'll know for sure when I pull up the carpet tonight.
[Re: Stanton]
#2437418
01/19/18 12:57 PM
01/19/18 12:57 PM
gtxncuda
Dearborn, Michigan
When I removed the seat, all four of the bolts had the 1/2" phenolic spacers installed between the track bottom, and the carpet. I seem to recall on my 70 GTX, only the two rearward studs used these, but not the fronts? I could be wrong, it's been a while... (1985)
[Re: gtxncuda]
#2437759
01/20/18 12:20 AM
01/20/18 12:20 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
AMD makes the plates & yes all get the rubber spacers
