#2436618 - 01/17/18 08:22 PM LOOKING AT 3 GEN HEMI
A/MP Offline
Loc: East Coast
All my cars are powered by pre - 1980 SB & BB. Looking at 3 Gem Hemi. Are there years that I need to avoid whether it is a motor or a running Charger/Challenger. Looking to build a 600+ Hp street car with mild manners.
#2436635 - 01/17/18 08:55 PM Re: LOOKING AT 3 GEN HEMI [Re: A/MP]
sp392 Offline
Loc: Etobicoke
Time to put together a FAQ for these engines and make it a sticky or a dedicated page of its own.
#2436682 - 01/17/18 11:04 PM Re: LOOKING AT 3 GEN HEMI [Re: A/MP]
72Swinger Offline
Loc: Nebraska
Mopar to the bone!!!
#2436728 - 01/18/18 02:45 AM Re: LOOKING AT 3 GEN HEMI [Re: A/MP]
gremlinsteve Offline
Loc: houston texas
Keep this in mind
Starting fresh with nothing you will probably have 12k into it all said and done
It's a close number So give or take a bit
That being said. You can buy a hellcat long block swap crate motor thingy
For 1;k delivered. It's a stout piece. Will easily support 1300
Rwhp also.
You also have a factory crate 392. Rated at 485
But it can be easily modified to support your 550-600 hp desire
I think there 9k
Add in the cost of the mopar engine controller at about 1700
Add in that cost with either crate motor and your set
Others sell long blocks cheaper. But remember. Small things like bolts
For the front timing cover can be a bear to find
With the crate motors you might need to swap the oil pan
And add a set of headers. Motor mounts
Along with an alternator and ac
If you want to run that
Transmission choice is up to you. I run a Hemi four speed
Behind mine. Any small block 727 will work
Nag1 too. But trans tunnel will need to be cut
The a518 will work but at your power level a 545rfe
Will not last a day
Dip stick I use is a wk1 jeep piece
Built for the Jeep Grand Cherokee
2006-2007 model. Tried the lokar
Piece bits horrible
If you decide to run a carb versus the injection you should get the ocp
Intake. Best of all worlds. Unless you can find the CASCAR
Single plane
There is a lot more information. But this should get the interest rolling
if You Like Gremlinsteve. Gremlinsteve Likes You.
#2436746 - 01/18/18 06:55 AM Re: LOOKING AT 3 GEN HEMI [Re: 72Swinger]
ric3xrt Offline
Loc: Trumbauersville PA
it's worth reading the 10 pages.
some good info in this thread also.
http://www.fastmopar.com/forum/index.php?topic=898.0
Also some good reading
http://board.moparts.org/ubbthreads/ubbt...tml#Post1970437
I've found for NA build the pre Eagle(03-08) blocks with Eagle heads(09-current) works the best.
Edited by ric3xrt (01/18/18 07:01 AM)
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
#2436825 - 01/18/18 10:39 AM Re: LOOKING AT 3 GEN HEMI [Re: ric3xrt]
RTSrunner Offline
Loc: Pittsburgh,PA
[/quote]
Do the early intakes fit the later Eagle head bolt patterns? Thinking in terms of a carburetor intake.
RT
25,708 Registered Members
196,895 Topics
Rubber Fitting for Small Block Water Pump
by MuuMuu101
01/23/19 11:14 PM
My car is a pig!
by mprhound
01/23/19 10:40 PM
Any 1/18 scale Mopar collectors out there?
by Gabmando
01/23/19 10:28 PM
Dodge RB 440 crankshaft question-
by Tek52
01/23/19 09:54 PM
