Last update....., she's done. #243630
03/05/09 12:58 AM
03/05/09 12:58 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Gradually getting this thing ready to drop in the new bullet. Been re-doing plumbing, wiring, etc.
As a point of reference, here is what it looked like before.
So I posted pics before of the new down bars, paint, brake lines, etc. Now we're getting to the wiring.
We basically made new harnesses and used the stock bulkhead connecters. MSD and two-step is mounted behind the glovebox door. New harness that is connected through the bulkhead connecter is mounted on the inner firewall. It has junction blocks for power, the MSD, and the linelock/transbrake wires.
Here is the brake and line lock junction block. That switch above the junction block is a starter switch for bumping over the motor when adjusting valves. The thing going through the grommet is the tube for the mechanical water temp sensor.
Here is the MSD junction block. The wire to the right going through the grommet is the alternator wire going back to the battery.
Here is the firewall and passenger innerfender. Idea was to tuck all the wires away and keep the engine bay as clear and uncluttered as possible. That thing in the middle of the firewall below the starter button is the temp gauge sending unit. I'll adding a -3 an bulkhead connecter next to it to hook up the oil pressure capillary tube.
Engine harness follows underneath the down bar along with the alt wire and will bridge to the motor behind the motorplate.
Last one, light and electic cooling fan harness runs along inner fender in stock location.
Just have to do the oil pressure line, install the new fuel pump, make new brackets for mounting the alt with the new motor plate and we'll be ready to put in the motor. Hopefully its in by end of day on Saturday.
Re: Latest progress update... [Re: G_bob] #243631
03/05/09 01:08 AM
03/05/09 01:08 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looking good. Cant wait to see and hear it in Vegas. Lots of work but I am sure it will all be worth it when you get it done.
We will be tearing mine a part for the umpteenth time tomorrow to get the new tranny in. Hopefully all will go well. This is the 4th year in a row I have had a failure a couple of weeks before the MATS. Beginning to think maybe I need to just not plan on going anymore. Maybe I can trick the car that way.
Re: Latest progress update... [Re: Al_Alguire] #243632
03/05/09 02:06 AM
03/05/09 02:06 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Very nice job. It's very clean.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Latest progress update... [Re: G_bob] #243633
03/05/09 03:15 AM
03/05/09 03:15 AM
Cab_Burge Online work
Cab_Burge  Online Work
Now would be the perfect time to move the brake line above the flywheel to the front of the car, I ran mine to the back side of the K member and didn't have to cut or lengthen it I have seen several NHRA tech that will bounce you on that in tech, not any of the local track techs
Re: Latest progress update... [Re: Cab_Burge] #243634
03/05/09 03:37 AM
03/05/09 03:37 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
So they don't like the brake line running above the bellhousing?
Where in the front did you route your line?
SDG Motorsports
Re: Latest progress update... [Re: DemonDust] #243635
03/05/09 06:33 AM
03/05/09 06:33 AM
Arizona
Chris'sBarracuda Offline
Arizona
Brakes: 3:1 General Regulations.. NHRA rulebook.
Brake lines must be steel, steel braided, or DOT approved flexible and routed outside framerail, or enclosed in a 16" length of 1/8" minimum wall thickness tubing securely mounted where line(s) pass the flywheel bellhousing area and not routed in the driveline tunnel. All brake lines must be attached to chassis as per OEM style; hoses must have mounting brackets; no tie wraps, tape, etc.
So now that you are totally confused..
Since my car lost its brakes during the wreck, I made myself aware of the rules..
Chris..
Re: Latest progress update... [Re: G_bob] #243636
03/05/09 01:29 PM
03/05/09 01:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks good Bob..........can`t wait to hear about you 9-sec passes.
Re: Latest progress update... (UPDATED) [Re: Thumperdart] #243637
03/08/09 02:00 AM
03/08/09 02:00 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Finished the last of the updates on the car today. Motor and trans are ready to go back in. Monday evening will will be d-day.
Installed the new fuel pump today. The Mallory 140 wasn't going to cut it, so a new 250 went in. Cut a hole in the sheet metal for the larger pump moter to fit, and the filters and lines ended up in the same place as before.
Re: Latest progress update... (UPDATED) [Re: G_bob] #243638
03/08/09 02:03 AM
03/08/09 02:03 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Rather than a direct wire from the switch to the pump as before. Put a relay at the battery box. Switch to the relay, and power direct from the battery (through a circuit breaker) to the relay and pump.
Re: Latest progress update... (UPDATED) [Re: G_bob] #243639
03/08/09 02:16 AM
03/08/09 02:16 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looking good. Cant wait to see and hear it at the MATS.
I think we are actually ready as well, other than a good cleaning. I think I am gonna put some new shoes on her before we go. Actually made some progress today myself, 164 MPH
Re: Latest progress update... (UPDATED) [Re: G_bob] #243640
03/08/09 03:10 AM
03/08/09 03:10 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Hey Glenn good work on the upgrades. Al that is some good speed what are the rest of the numbers with your repaired tranny.
Re: Latest progress update... (UPDATED) [Re: 68Fastback] #243641
03/10/09 09:22 AM
03/10/09 09:22 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Another late night last night and STILL didn't get it done. Got close though.
Here is the unit bolted together with the new sheild on the trans.
And hanging, ready to go in.
It took a little coaxing. And we had to pull the starter back off, drop the drag link and slide back the torsion bars to slide the headers in from underneath, but the headers did go in with the motor bolted in place. Had to clearance them a little around the passenger side torsion bar, and they're basically touching the frame on both sides, but at least they still fit in there with the raised exhaust ports on the Victors. I was a little worried.
Got a few minor things to do, top-side wires, carb fuel lines, move some new wiring that ended up too close to the headers, etc. But at least it is in there, and all things considered, went in pretty smooth.
The bottom-side is buttoned up, drive shaft is back in, trans linkage connected, etc. Don't know if my exhaust will fit back on there though.
Anyway, here's a couple pics at the end of the night last night. If I can get away from work at mid-day today, I may get it done and running this afternoon.
At least it LOOKS good.
Re: Latest progress update... (UPDATED) [Re: G_bob] #243642
03/10/09 09:31 AM
03/10/09 09:31 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
LOoks good Glenn, did you have to clearance the tunnel for the sheild?
Ted
Re: Latest progress update... (UPDATED) [Re: Diego_Ted] #243643
03/10/09 10:18 AM
03/10/09 10:18 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Glen,Looks good. Oh yeah Happy Birthday as well
Re: Latest progress update... (UPDATED) [Re: Diego_Ted] #243644
03/10/09 10:56 AM
03/10/09 10:56 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Ted
Just bent the pinch-weld back and hammered it flat, that was it.
It's tight though.
Re: Latest progress update... (UPDATED) [Re: G_bob] #243645
03/10/09 11:07 AM
03/10/09 11:07 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
LOOKS GOOD!!! happy birthday!
did you have to do anything to the rockers to make the valve covers fit?
Re: Latest progress update... (UPDATED) [Re: 70blackfish] #243646
03/10/09 11:10 AM
03/10/09 11:10 AM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Awesome!
Re: Well, the motor is in, but no fire yet... [Re: G_bob] #243647
03/10/09 11:49 AM
03/10/09 11:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks great and can`t wait to hear the results.....oh, HAPPY B-DAY....
Re: Well, the motor is in, but no fire yet... [Re: Thumperdart] #243648
03/13/09 01:56 AM
03/13/09 01:56 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Engine is plumbed, wired and running. Sounds good, revs quick. Haven't taken it for a drive yet though.
Final pics of full install.
Again, here is the before...
And after....
Re: Well, the motor is in, but no fire yet... [Re: G_bob] #243649
03/13/09 02:33 AM
03/13/09 02:33 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Looks awesome
That thing will def haul the mail
SDG Motorsports
