1969 Hemi bell housing/flywheel options... #2435645
01/16/18 02:21 PM
01/16/18 02:21 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
While back I had this info saved and now I can't find it...old age I guess. Now I'm ready to buy the parts so I need to confirm again if I got this right.
The 1966-69 426 Hemi used a 172 tooth flywheel with a 11" 2892259 bell housing and a direct drive starter.
That setup can be replaced with a 11" 2892262 or 2892626 bell housing, 143 tooth flywheel and a high torque starter can be used.
Do I have this correct? work
Thx
Wolf.
Re: 1969 Hemi bell housing/flywheel options... [Re: Wolfe440] #2435715
01/16/18 04:08 PM
01/16/18 04:08 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I would recommend that you use the 10.5" bell/flywheel like the 70-1 cars used. Especially with stock exhaust manifolds.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 1969 Hemi bell housing/flywheel options... [Re: Dan Brewer] #2435772
01/16/18 05:37 PM
01/16/18 05:37 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Thanks for reply. I didn't know 10.5" would be a better choice. I have a couple of bell housings for 11" which is why I was hoping to save money not having to buy a new housing. And yes I am using the stock exhaust manifolds.
Is there a casting number for the 10.5" bell housing?
The 10.5" flywheel....do you know what the teeth count is?
With the 10.5" will I be able to bolt in a high torque starter and function with no issues?
Thx,
Wolf
Re: 1969 Hemi bell housing/flywheel options... [Re: Wolfe440] #2435794
01/16/18 05:58 PM
01/16/18 05:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Click on the link in Dan's signature line above, it will show the various casting numbers. The 10 1/2" flywheel is 130 tooth and changing to it will allow the use of all gear reduction starters.
You might have to change the Z-bar.
Re: 1969 Hemi bell housing/flywheel options... [Re: John_Kunkel] #2435831
01/16/18 06:43 PM
01/16/18 06:43 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
I'm ok if need to change z-bar. I found the info, very helpful, thank you!
Wolf
Re: 1969 Hemi bell housing/flywheel options... [Re: Wolfe440] #2437671
01/19/18 09:24 PM
01/19/18 09:24 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Thx,
Wolf
John is correct on the info given. No need to change the z-bar or any clutch linkage. We can do some trading on bells if you want. Best to contact me through the website. Not on here often.
Dan
