Tire Size55 #2435773
01/16/18 05:37 PM
01/16/18 05:37 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
I have 25560R15 rear tires on my duster.Gear ratio is 355.If I switch to a 23560r15 wil I lower or raise the actual ratio
Re: Tire Size55 [Re: Crabra] #2435790
01/16/18 05:57 PM
01/16/18 05:57 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
2556015 is 27 inches tall.
2356015 is 26.1 inches tall
You will be lowering your final drive.
Your final drive of 3.55 will make it feel like a guestimate of 3.68 or more.
Quicker off the line,but highway RPM's will increase slightly by 50-100RPM's.
Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Tire Size55 [Re: 68Cbarge] #2435860
01/16/18 07:56 PM
01/16/18 07:56 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Quicker off the line is what i am looking for.Thanks
Re: Tire Size55 [Re: Crabra] #2435906
01/16/18 09:13 PM
01/16/18 09:13 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Going from a 255 to a 235 is shorter, but it is also less tire on the road for traction. You may not get off the line quicker just because you may loose traction.
You may be better off with a stickier 255.
Re: Tire Size55 [Re: Crabra] #2437661
01/19/18 08:56 PM
01/19/18 08:56 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I doubt it is a significant enough difference to be felt and may only be measurable by a stop watch.
