How to replace the rubber bushings on A-Body sway bar? #2435327
01/16/18 12:12 AM
01/16/18 12:12 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Is it true that you have to remove the bottom bracket/plate to replace the rubber bushings on an A-Body sway bar?
Re: How to replace the rubber bushings on A-Body sway bar? [Re: vinnyd76] #2435458
01/16/18 04:25 AM
01/16/18 04:25 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: How to replace the rubber bushings on A-Body sway bar? [Re: vinnyd76] #2435538
01/16/18 12:04 PM
01/16/18 12:04 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used the technique posted by macmic87. At the time, I didn't have the ability to weld the brackets if I cut them. I would imagine that cutting and welding would be the easiest way to replace the bushings but it is possible to replace them without cutting......just more time consuming.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: How to replace the rubber bushings on A-Body sway bar? [Re: FJR doc] #2435666
01/16/18 03:03 PM
01/16/18 03:03 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
A lot depends on the variation in bracket/opening size. If the bracket/opening is on the low-side of the tolerances it can be extremely difficult to get the bushing in. On my Dart I was able to get one side in but not the other (detailed in the threads referenced above).
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
