Neutral Safety switch #243510
03/04/09 10:42 PM
03/04/09 10:42 PM
Denver Co.
BadBelvedere Offline OP
Denver Co.
Any ideas? I have a painless 8 switch panel.with a msd ignition with out a ballast. I wired in a stock starter relay. I hooked a wire on the right lower plug. I think that is the place for the neutral safety? I have a switch on the shifter. one wire is grounded the other to the relay. The car still starts in gear? what am I doing wrong?
Re: Neutral Safety switch [Re: BadBelvedere] #243511
03/04/09 10:56 PM
03/04/09 10:56 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
First, verify that you have the wire on the ground post of the relay. Second verify that the switch is not shorted out and grounding all the time.
Re: Neutral Safety switch [Re: BadBelvedere] #243512
03/04/09 11:05 PM
03/04/09 11:05 PM
Denver Co.
Denver Co.
Which post is the ground post? I have it pluged to the bottom left one. the other one(on the right side) went to the old ballast. That one is not pluged to anything
Re: Neutral Safety switch [Re: BadBelvedere] #243513
03/04/09 11:07 PM
03/04/09 11:07 PM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
what shifter are you using ??? I just found out my local track will now require all cars to have one. So i'm scrambling to fix one myself
Re: Neutral Safety switch [Re: BadBelvedere] #243514
03/04/09 11:09 PM
03/04/09 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 2 wires coming from your shifter switch go to
the wire coming off of your starter button then on
to the solenoid.... in other words..... hot going
to your starter button.... out of the other side of
the button to one wire going to the shifter(either wire)
out of the shifter switch to the solenoid.... your
just putting the shifter switch in line on the starter
button
Re: Neutral Safety switch [Re: MR_P_BODY] #243515
03/04/09 11:14 PM
03/04/09 11:14 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Middle plug terminal on the trans connector is the neutral switch. Simply run that to the N side of the starter solenoid, or if you shifter only has one connection...run it there
Re: Neutral Safety switch [Re: MR_P_BODY] #243516
03/05/09 12:12 AM
03/05/09 12:12 AM
Denver Co.
Denver Co.
I have a B&M Pro Stick. Thanks guys, That helps alot.
Re: Neutral Safety switch [Re: MR_P_BODY] #243517
03/05/09 12:18 AM
03/05/09 12:18 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
button
This is how mine is wired as well.
Probably the easiest way IMO
