Re: References for potmetal & brake booster restoration?
[Re: Dixie]
#2435142
01/15/18 07:08 PM
01/15/18 07:08 PM
Posts: 4,115 MD
floyd
MD
Booster Dewey for the booster: http://boosterdeweyexchange.com/No experience with pot metal resto.
[Re: Dixie]
#2435182
01/15/18 08:19 PM
01/15/18 08:19 PM
Posts: 5,268 NY
70440+6bbl
NY
[Re: Dixie]
#2435190
01/15/18 08:32 PM
01/15/18 08:32 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hey Guys, who are the go-to people these days for pot metal and brake booster restoration?
Thanks! Randy Booster Dewey as recommended, as far as pot metal, if it's pitted your going to PAY dearly! if it looks "unstable" to the plater, most will refuse to de-cromate it for fear of losing it in solution, never mind re-plating it, best to replace with NOS, or repro pcs if available as pot metal is expensive, if you want nice potmetal work, Advanced plating in Nashville Tenn, Steve and crew do the utmost in quality work and wrecking your wallet at the same time
[Re: Dixie]
#2436564
01/17/18 09:33 PM
01/17/18 09:33 PM
Posts: 6,717 KY
65pacecar
KY
I have had nice pot metal work from Pauls Chrome, also excellent work from Iversons Automotive http://www.iversonautomotive.com/, I think Advanced Plating in Nashville may do it too, never used them but always heard great things about them. I had a guy in Northern KY. do excellent work for me on Pot Metal too, I will see if he is still in business or retired yet.
[Re: floyd]
#2436620
01/17/18 11:28 PM
01/17/18 11:28 PM
Posts: 643 southern conn
1969gtx
southern conn
I have had apple hydraulic do master cly.good job quick turn around time. thay will give you a est. phone 631 369 9515
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: Dixie]
#2436690
01/18/18 02:20 AM
01/18/18 02:20 AM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
Friend of mine got burned bad by Apple Hydraulics. Had a hold off valve rebuilt and it acted like a one way valve letting fluid to the rear brakes but not back up to the master cylinder. Burned up his rear brakes and discolored his drums to the point they warped from excessive heat from the brakes being constantly on. Apple never made good on it.
inherited a 69 roadrunner from my grand pop.
[Re: Dixie]
#2436879
01/18/18 03:22 PM
01/18/18 03:22 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
Some members here have also been screwed over by Whitepost restorations on Master cylinder rebuilds. Brake and Equipment Warehouse in Minneapolis is the go-to shop to use for rebuilding Mopar Master cylinders. http://brakeandequipment.com/
[Re: Dixie]
#2437742
01/19/18 11:57 PM
01/19/18 11:57 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
For pot metal work, you must practically interrogate the guy as to his process. Some bumper shops will chrome right over the pits. Others say they will keep copper plating it til the pits are filled (along with any detail left on the piece). Some shops will, and I quote 'grind out the pits'. Some will fill the pits with real bondo or some other plastic. The best will strip the part, glass bead it to remove any dead/oxidized pot metal, then fill the pits with pewter or lead or some other type of metal, then into the copper, and so on. It's a lot like doing body work when it's done right, and that's why it's so pricy. The better your cores the less expensive the part is to plate. But don't be surprised if after they strip a pristine part they find oxidation or pitting under it. This was the process back when I had a bunch of work done 10+ years ago. Materials may have improved or processes changed. Part of the cost is in the chemicals - not buying them when new, but proper disposal of them when spent. You just don't pour that stuff into the sewer, lest you want to create a Superfund site and poison water fowl and wildlife for many miles around, not to mention people's drinking water or fishing.
