how do i pull the axles on a 7 1/4 ????? #243466
03/04/09 10:12 PM
03/04/09 10:12 PM
colorado
chargermop Offline OP
colorado
are there c clips???????????i have the 5 nuts off ????
Re: how do i pull the axles on a 7 1/4 ????? [Re: chargermop] #243467
03/04/09 10:16 PM
03/04/09 10:16 PM
Friendsville, TN
Reverend_Ron Offline
super street
super street
Friendsville, TN
I believe so - c-clips behind the cover! Did it in 1986...
68 Roadrunner, 383,4-spd 71 Superbee, Citron Yella, 383,slapstick 71 Charger 500, Autumn Bronze, 383,4-spd, A/C 72 Imperial, 2-dr hdtp 74 Charger SE, 440-auto, sunroof 84 Crew Cab Dually, 440-auto 01 Quad Cab Dually, HO Cummins;6-spd 08 H-D, Softail Custom 08 Challenger, 6.1 Hemi
Re: how do i pull the axles on a 7 1/4 ????? [Re: Reverend_Ron] #243468
03/04/09 10:20 PM
03/04/09 10:20 PM
colorado
colorado
the rear end is from a 1970 challanger..
Re: how do i pull the axles on a 7 1/4 ????? [Re: Reverend_Ron] #243469
03/04/09 10:22 PM
03/04/09 10:22 PM
I dont remember if it is C clips or a dead bolt but take off the back cover & you'll see what you need to do.
Re: how do i pull the axles on a 7 1/4 ????? [Re: chargermop] #243470
03/04/09 10:26 PM
03/04/09 10:26 PM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
It's been a few years, but I definitely don't remember having to take off any c-clips when I replaced the bearings on my old one. It was in a '70 Barracuda and I don't remember doing anything but unbolting it at the flange. Like I said though, it has been while so I wouldn't trust my memory.
Darrah Heath
Re: how do i pull the axles on a 7 1/4 ????? [Re: VT_Dart] #243471
03/04/09 11:01 PM
03/04/09 11:01 PM
St. John's Newfoundland
440newport Online content
440newport  Online Content
They don't have c clips but from my experience the axles are usually stuck in there pretty good. Much more than say an 8 3/4. One thing I heard to try is back the 4 flange nuts off about 1/8" and then drive the car around in a circle a few times to pull the axle out some so it's easier to remove later.
Re: how do i pull the axles on a 7 1/4 ????? [Re: 440newport] #243472
03/04/09 11:13 PM
03/04/09 11:13 PM
My mistake, I guess they dont have clips(or a dead bolt) & yours are just stuck. glad that got straightened out before you took off the cover with all that ensuing mess to deal with Put the drums back on backwards with a few turns of the lug nuts & use the drum as a slide hammer,they'll pop loose
Re: how do i pull the axles on a 7 1/4 ????? [Re: RapidRobert] #243473
03/05/09 12:05 AM
03/05/09 12:05 AM
colorado
colorado
thanks for the help you are right no c clips.. Just needed a BF hammer......
Re: how do i pull the axles on a 7 1/4 ????? [Re: chargermop] #243474
03/05/09 01:27 AM
03/05/09 01:27 AM
Kentucky
Hillbillyracer Offline
mopar addict
mopar addict
Kentucky
I always use a slide hammer and they pop out in two or three smacks.No clips,the 8 1/4 rear has the clips
1972 Dodge dart,,1964 Plymouth Valiant station wagon,1976 Dodge M880 truck,1995 Dodge 3500 rollback
