Indy SR's #2434431
01/14/18 02:54 PM
01/14/18 02:54 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Last year I reworked a set of older Indy SR's.
These were probably about 1998 vintage or so. The early ones had more of a "D" shaped chamber. The newer ones have the heart shaped chamber.
The newer chamber is cast with more space around the valve adjacent to the chamber wall.
The early ones had noticeably weaker low/mid-lift flow with the valves being more shrouded by the chambers.
I have only a couple pics, and not any good pics of the complete OOTB chamber shape.
The early heads also had quite a bit more meat that needed to be cut out of the bowls, as well as having a pretty chunky guide boss.
They can end up as good as the newer version, it just take more work to get them there.
The first pic is after the valve seats were cut along with a chamber relief cut.
You can see the extra material under the seat and the guide boss that will be getting trimmed away.
The ootb flow numbers aren't really that good at all, and aren't any better than a half way decent ported 906 until over .550 lift, and the low/mid-lift flow is way down compared to even a mild bowl blended stock head.
These are the kinds of heads where if you just ran them ootb, you were likely going to be disappointed.
Tested on a 4.375 bore, 28" pressure, radius plate on intake.
OOTB test is std port, ported test is MW size opening.
A- OOTB
B- ported
Intake:
Lift------A/B
.100---69.0/73.1
.200--124.9/146.4
.300--173.2/209.8
.400--218.0/260.8
.500--255.9/310.7
.550--268.3/326.9
.600--274.8/336.4
.650--278.5/342.0
.700--281.6/347.7
.750--283.5/353.4
.800--284.2/359.1
Exhaust:
Lift------A/B
.100---52.8/ 57.2
.200-- 89.2/111.6
.300--127.7/162.4
.400--162.4/205.8
.500--187.2/236.8
.550--196.7/248.3
.600--203.2/252.1
.650--206.2/256.7
.700--208.1/261.6
.750--210.8/266.2
.800--212.7/268.1
Re: Indy SR's [Re: fast68plymouth] #2434437
01/14/18 03:05 PM
01/14/18 03:05 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
They look like they clean up real well. Thanks for the pics.
[image][/image]
Re: Indy SR's [Re: fast68plymouth] #2434438
01/14/18 03:05 PM
01/14/18 03:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Very nice gains for sure. These seem to be the forgotten head out there anymore these days. I have always seem a fan for a nice streetcar and don't understand why they get overlooked so much.
Re: Indy SR's [Re: Al_Alguire] #2434450
01/14/18 03:20 PM
01/14/18 03:20 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice work, no doubt. The last bench testing I did on 'low floor' ports I found the area in the chamber along the shortside radius was pretty sensitive because it is a continuation of the shortside. I would be curious how much flow would be affected (negatively) if you milled the chambers to the intake seats. I believe the middle peak between the valves ADDS flow when done correctly so, i would think the newest casting would be capable of higher cfm. However, that area appeared less 'sensitive' than optimizing the chamber wall side transition form the valve seat.
Re: Indy SR's [Re: HardcoreB] #2434454
01/14/18 03:25 PM
01/14/18 03:25 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Chad Spier, over on The Bullet, has some nice low-port SBC models that i feel are worth viewing, particularly on the guide tail and floor shapes.
Re: Indy SR's [Re: fast68plymouth] #2434458
01/14/18 03:31 PM
01/14/18 03:31 PM
NY
challenger451ci Offline
NY
Very nice! Those numbers are pretty close to what mine were from Modern many years ago. I just went 8.99 @ 150 in my 3480lb barge so they can make half decent power with a whiff of spray.
You're right, OOTB, pre MW porting they DID NOT set the world afire!
Re: Indy SR's [Re: fast68plymouth] #2434461
01/14/18 03:42 PM
01/14/18 03:42 PM
So. Burlington, Vt.
So. Burlington, Vt.
Sean, SR's aren't low floor heads.
They have the tallest sort turn of any of the Indy heads I've seen.
Way taller than a -1.
I agree that the newer chambers with the added material between the valves should be "better", but it doesn't seem to make much difference in the "big number" on these things....... At least with what I'm doing.
If you're looking for 360-370, it might be more of a player.
Get the short turn right, pinch opened up enough, bowl/guide boss area sized right, clean up the rest of the port...... Mid-350's@.700+ are usually the norm at MW size.
Re: Indy SR's [Re: Al_Alguire] #2434471
01/14/18 03:57 PM
01/14/18 03:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
Al, I think it just comes down to cost.
Even the newest SR's require more work than their competition to get them past the "disappointment" stage....... And time is $$$, and the heads aren't bargain priced to begin with.
EZ's have much more user friendly intake ports(less work to get decent flow), and they don't need special headers or the external oiling lines(I actually prefer the external lines myself), and they're a little less $$.
The TF heads have really changed the game for the average guy looking for a 550-700hp BB Mopar build. You just can't touch anything else at that price point that gives the same bang for the buck.
Re: Indy SR's [Re: fast68plymouth] #2434475
01/14/18 04:19 PM
01/14/18 04:19 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I'm just curious. Why the preference for external oil lines?
I love seeing this kind of post, BTW!
'63 Dodge 330
11.19 @ 121 mph
Re: Indy SR's [Re: GY3] #2434530
01/14/18 05:53 PM
01/14/18 05:53 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I love seeing this kind of post, BTW! [/quote]
Yes, I agree.
Thank you for taking the time to post these types of things Dwayne!
Re: Indy SR's [Re: fast68plymouth] #2434573
01/14/18 07:13 PM
01/14/18 07:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
It's full time oiling, and restrictors are easily changed if you want to increase/decrease the flow to the top end....... Without resorting to either a grooved #4 cam journal or bearing...... Both of which take oil away from the #4 main.
I look at the external lines that are used on some Indy heads as an item in the "pros" column.
Cost considerations aside, I think it would make for an interesting test to compare some TF240's against some similarly flowing std port SR's on a 700hp-ish 505 or 511.
The SR's have such differently shaped intake ports than the TF, along with a raised, better flowing exhaust port........I'd love to see how that would play out.
Would it make any real difference or not?
Re: Indy SR's [Re: fast68plymouth] #2434582
01/14/18 07:28 PM
01/14/18 07:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
quote]
Would it make any real difference or not? [/quote]That would be a comparison that I would be very interested in also, I am pretty happy with my ootb 240's, a before and after porting comparison would be some very interesting info also.
Re: Indy SR's [Re: fast68plymouth] #2434615
01/14/18 08:59 PM
01/14/18 08:59 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I've got OOTB SRs on my 440. The numbers you posted make me think that it may be time to get some work done on them. work
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Indy SR's [Re: fast68plymouth] #2434619
01/14/18 09:18 PM
01/14/18 09:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
If they are the "newer" ones with the heart shaped chambers, the OOTB low/mid-lift numbers are a little better.
I brought this up from the "Best of Moparts" forum:
440-SR head: 4.375 bore, 28" test pressure, radius plate on intake, no flow tube on exhaust.
Intake ports;
A- OOTB std port, zero porting
B- OOTB CNC Maxx port. this is an option from Indy where they CNC the intake opening to MW size, along with doing a CNC bowl blend. no additional porting or valve seat work.
C- this is how i like to prep these heads, so you get the benefit of stepping up from a stock head or RPM type head.
this particular port started out as the CNC Maxx job, then got the chambers ported, my valve job, back cut valves, "bowl ported", guides streamlined, short turns reworked.
lift----A----B----C
.100--70.7/ 71.9/ 74.7
.200-134.2/131.7/147.6
.300-195.2/189.1/212.0
.400-238.2/239.3/265.1
.500-263.6/284.9/305.1
.550-275.6/302.9/319.7
.600-279.3/286.1/329.4
.650-280.3/286.8/336.6
.700-282.3/286.1/343.3
Exhaust ports;
D- OOTB std head, zero porting
E- OOTB Maxx head, CNC bowl blend
F- Maxx head, PRH valve job, back cut, mild full port and polish. this is how i like to do these to match the intake port in column "C".
lift----D----E----F
.100--56.5/ 54.7/ 56.9
.200-104.1/ 95.4/131.4
.300-142.6/131.4/157.2
.400-171.1/159.9/197.1
.500-195.9/182.9/225.9
.550-203.3/192.4/236.2
.600-209.5/200.7/245.3
.650-214.5/205.7/253.3
.700-218.2/210.3/255.6
These heads will flow 320+ by .600 lift while retaining the std port opening with a good valve job, bowl work, chamber clean up, guide trimming, and cleaning up the pushrod pinch.
Re: Indy SR's [Re: fast68plymouth] #2434666
01/14/18 10:44 PM
01/14/18 10:44 PM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
4.500 Bore x 4.150 stroke. Great torque. Always left and 60ft. The best leaving @3200. Best e.t. 9.77@139 3390lb. with driver.
Woodruff Carburetor Specialties
330-799-9479
Re: Indy SR's [Re: Al_Alguire] #2434675
01/14/18 10:53 PM
01/14/18 10:53 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The raised exhaust port position means header choices can be problematic, depending on the chassis they are going into. Back in the day they were a decent head and you just had to deal with the header issues, but with so many standard exhaust port position heads out there now, which would you choose - the SRs that might require a custom header or something else? Been sitting on a set for a few years waiting to go into an a body, but am contemplating the trick flows because of the header availability and relative OOTB ability of them.
Re: Indy SR's [Re: fast68plymouth] #2434682
01/14/18 11:02 PM
01/14/18 11:02 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Like fast said, more than enough to break my oldiron block
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Indy SR's [Re: Sixpak] #2434695
01/14/18 11:15 PM
01/14/18 11:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I am curious as to how much improvement can be had with port work on the 240's, I am sure the SR's will out perform them but by how much,and is there enough gain to be had with the 240's to make it worth the expense.
Re: Indy SR's [Re: fast68plymouth] #2434706
01/14/18 11:26 PM
01/14/18 11:26 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Is there any work to be done on the SR CNC295’s or are they already at max effort?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Indy SR's [Re: fast68plymouth] #2434708
01/14/18 11:32 PM
01/14/18 11:32 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Those out of the box numbers look familiar.
