how high of a reading should I expect on a vacuum gauge #243452
03/04/09 09:54 PM
03/04/09 09:54 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
I just finished putting EQ Magnum heads on my '83 318. along with the associated 1.6:1 Magnum rockers, etc. I also put in a stock replacement 360-2 barrel cam. Melling brand. 0.410 lift on a stock LA motor, but 0.437 lift with the 1.6 Magnum rocker gear. extremely close to a COMP 252 at 1/2 the price. Performer intake, AFB #9636 625 CFM. Eddy double roller T chain set; cam installed dot to dot, at 0* adv/retard.
Motor runs dead smooth, and I can set my idle at 650 RPM, w/o a problem. (I've actually got it at 700 though) But I'm worried a bit, that I can only get a best reading of 16" on my vacuum gauge (verified with a 2nd gauge); though that reading is rock steady.
Runs great, huge difference in power, between now and when it was a completely stock, 318 2 barrel motor.
but, I had a steady 19.5" then. Is 16" to be considered "normal" for the new combo?
this cam, in a 360, gives 19-20" vacuum.
(1) will the 42 less CI, influence the reading THAT much, with a given cam???
(2) how 'bout the increased flow potential of the EQ heads, as compared to the original 318 heads(they were not the "302" ones, but standard open chamber "163"s) I'm thinking that the larger ports and valves can flow more air, so there can be less difference between atmospheric pressure vs inside-the-engine pressure(or vacuum)
Yes, this is a heavy truck, but now it moves much easier down the road, with much less gas pedal needed to do the same as before. Meaning the engine now does not have to work as hard as it used to. (or does it)
I'm definitely not after Neon type MPG (or I would not be driving a truck in the 1st place, would I) BUT I want what I had before, at least; if not a bit better. I had an '81 W 150 with a TQ on a 318, that surprised alot of people in that department, so I'm using that truck as my "bench mark". (though that engine was 100% OEM stock)
Lower vac readings, usually mean thirstier engines, from what I've seen in the past.. I got 12-13 MPG from this truck before the swap; driver, weather loading (or not) percentage of hwy to in town miles all being equal, think I can expect that to stay the same or maybe even increase, even?
Re: how high of a reading should I expect on a vacuum gauge [Re: volaredon] #243453
03/04/09 10:37 PM
03/04/09 10:37 PM
I am going to be doing pretty much what you have done but I am going to adv the cam 2 degrees(& maybe try 4) as I have the cam bushings & I might as well experiment with them. It sounds like you are in good shape even with your idle vac being lower & I dont have an answer for that.
Re: how high of a reading should I expect on a vacuum gauge [Re: volaredon] #243454
03/04/09 11:08 PM
03/04/09 11:08 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
16 sounds like more than enough to me. if it was 13 or less id then id worry
Re: how high of a reading should I expect on a vacuum gauge [Re: aarcuda] #243455
03/04/09 11:46 PM
03/04/09 11:46 PM
ILLINOIS
V
V
ILLINOIS
so a reading of 16 is realistic?? I have no signs of any vac leaks and the needle is steady there but just "seems" low. What's "magical" about a reading of 13? Is that like the minimum needed to run the brake booster or something?
Re: how high of a reading should I expect on a vacuum gauge [Re: volaredon] #243456
03/04/09 11:52 PM
03/04/09 11:52 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
heck ya, thats great.
shoot, mine reads 10 in neutral and 6 in gear (but i have a much bigger cam than that)
Re: how high of a reading should I expect on a vacuum gauge [Re: aarcuda] #243457
03/05/09 01:47 AM
03/05/09 01:47 AM
ILLINOIS
V
V
ILLINOIS
I have not extended the vac line to see the gauge in the cab in gear or under load, but that 16" is at idle in Park.
Re: how high of a reading should I expect on a vacuum gauge [Re: volaredon] #243458
03/05/09 01:59 AM
03/05/09 01:59 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
I would drive it a bit before I worried about it. None of my 318s have had more that 16-17 inches of vac either.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: how high of a reading should I expect on a vacuum gauge [Re: phantomx] #243459
03/06/09 03:05 AM
03/06/09 03:05 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Did you try playing around with your initial timing to see if you can get some more vacuum?
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: how high of a reading should I expect on a vacuum gauge [Re: kick_the_reverb] #243460
03/06/09 12:52 PM
03/06/09 12:52 PM
ILLINOIS
V
V
ILLINOIS
Ran
Yup I did; its got twice the initial advance it used to with the old cam and worn out T chain. (16* now vs 8* before, same dist. as before) any more and it pings; I have my timing max'd out; though I have not yet played with cutting down the vac advance with the allen head inside the pod and upping the initial further yet.
As far as advance, I probably should have degreed the cam even though I'm using a stock OE 360 replacement since it is so close to what the COMP 252H that I originally was gonna go with. I may and whether it is "off" or not I may advance it 4* since I have the 3 keyway timing set.
