Cometic/Trick Flow Cometic #2434464
01/14/18 03:48 PM
01/14/18 03:48 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Is there anything "special" or different about the Trick Flow Cometic head gaskets (made by Cometic) vs the Cometic head gasket? I see they are $12 more a gasket. I was planning on just getting Cometic ones, but wanted to check 1st.
Re: Cometic/Trick Flow Cometic [Re: DusterKid] #2434484
01/14/18 04:36 PM
01/14/18 04:36 PM
AndyF Offline
AndyF  Offline
Only person who knows the answer to that question is the purchasing agent at Trick Flow and I doubt he is going to log in here to tell you.
So you'll just have to take a guess. My guess is that it is just a Cometic gasket with a Trick Flow sticker on it but I could be wrong.
Re: Cometic/Trick Flow Cometic [Re: AndyF] #2435044
01/15/18 03:59 PM
01/15/18 03:59 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Probably just like TF selling re-labeled Quick Fuel carbs...
Re: Cometic/Trick Flow Cometic [Re: DusterKid] #2435305
01/15/18 11:23 PM
01/15/18 11:23 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
Maybe the TF Cometic gaskets will cover the machining dimples they had on the earlier 240 heads? I had oil leaks from the dimples using the felpro gaskets they suggested. I had to fill the dimples with "right stuff" to get the leaks to stop.
I am using the regular Cometic gaskets without any problems.
