Hemi solid mech./solid roller cams ? #2434330
01/14/18 11:38 AM
01/14/18 11:38 AM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
Looking for suggestions on a solid mechanical / solid roller cam for my Hemi street/strip car . E-body 3600# 4-speed , 4:10 gears 28 inch tall tire. Would like something in the 550-560in lift . motor will be 10.25 comp .030 over Thanks
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434384
01/14/18 01:24 PM
01/14/18 01:24 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Any of the better known Hemi builders should be able to help you get the cam you want.
I got mine from Ray Barton. 565/547 with 250* SFT. I am very happy with it.
Master, again and still
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434386
01/14/18 01:26 PM
01/14/18 01:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
How many cubes, and what shift rpm are you shooting for?
Re: Hemi solid mech./solid roller cams ? [Re: Dragula] #2434444
01/14/18 03:10 PM
01/14/18 03:10 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
5500-5800 I'm thinking
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434463
01/14/18 03:44 PM
01/14/18 03:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you're really going to drive it on the street, then I would say the Isky ez roll lifters. But they are $$$$
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434526
01/14/18 05:49 PM
01/14/18 05:49 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What is the stroke? That's pretty important when picking a cam.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434539
01/14/18 06:13 PM
01/14/18 06:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If that's all you're going to turn it why not a hydraulic roller?
Re: Hemi solid mech./solid roller cams ? [Re: Hemi_Joel] #2434566
01/14/18 07:03 PM
01/14/18 07:03 PM
14437
HOTHEMI Offline OP
HOTHEMI  Offline OP
14437
it's a stock stroke .030 10:25 comp. I have a 524/507 MP hyd cam in it now . Would like to go with a solid or solid roller with more lift .Like the sound of a solid cam Hemi , I have the motor apart for freshening up now and thought it's a good time give it little power
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434625
01/14/18 09:35 PM
01/14/18 09:35 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I think you'll find that the duration is a more accurate indicator of the RPM range than the lift. Shifting your Hemi under 6,000 won't take much cam at all.
The .565/.547 250* cam in my 540 pulls to 6,800.
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434699
01/14/18 11:21 PM
01/14/18 11:21 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Me thinks the required spring pressures determine the life of the lifter.I found out the hard way.I'm on the same set of comp 848's since March of 04.Rebuilt for the second time last winter.
My lift is mid 6s with spring pressure low 600lbs over the nose in a street driven hemi that sees over 1000 miles a year and if I'm lucky,,,,,60 passes.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434704
01/14/18 11:23 PM
01/14/18 11:23 PM
hemi-itis Offline
hemi-itis  Offline
Picture was the old comp 829s.
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434717
01/14/18 11:47 PM
01/14/18 11:47 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
"You like the sound of solid Hemi cam", do you mean the clatter of the valve lash? for what you say your RPM range is don't waste your money on a upgrade.
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434729
01/14/18 11:59 PM
01/14/18 11:59 PM
On your deal I would buy and use the Comp Cams282S grind, part number 24-308-4, and install it at 103 to 105 intake lobe center and use the lash as recommended, maybe experiment with both .004 to .006 tighter and looser to see what sound and driving you like the most scope twocents
All the stock street hemi cams with mechanical lifters, 1966 to 1969, had .028 hot recommended lash work shruggy
Tightening them up .006 to .012 made them a lot quieter and helped the bottom end power work shruggy
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434755
01/15/18 12:24 AM
01/15/18 12:24 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I think it would be kinda hard to keep under 6,000 the way they rev.
I remember my buddy letting me drive his 64 dodge lightweight Hemi, nite and day difference from my 64 max wedge. Mine had a 5.13, his a 5.57, it hit the shut off (8500) on 2 & 3 because I wasn't expecting it to rev that fast. LOL
Re: Hemi solid mech./solid roller cams ? [Re: cudaman1969] #2434856
01/15/18 05:20 AM
01/15/18 05:20 AM
A race hemi compared to a pump gas street hemi is like comparing a 383 magnum to a 425 HP M.W. shruggy
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2434864
01/15/18 05:46 AM
01/15/18 05:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Since its a street car I am guessing it will be pump gas ? Whats the pump in your area ? I can find 93 at some stations in my area but most are 92. Course I would keep that in mind when picking a cam. Or have a good cam person or company spec a cam for your combo as that's what I did. I had Dwayne Ported spec a solid flat tappet for my pump gas combo and its nice to know I can pull in any station in my area and gas up and the car will run good with no detonation. Good luck with it. Ron
Re: Hemi solid mech./solid roller cams ? [Re: HOTHEMI] #2435539
01/16/18 12:06 PM
01/16/18 12:06 PM
an8sec70cuda Offline
Talk to Dwayne Porter (Fast68plymouth here on the board). Get a cam spec'd by him and you'll never need to worry if there's a better cam out there for your combo again.
802-951-1955
CHIP
'06 GMC 2500HD LBZ Duramax
