Re: best intake for mild street 383?
[Re: orange elephants]
#2434243
01/14/18 02:32 AM
01/14/18 02:32 AM
Posts: 10,219 Someplace you aren't
SomeCarGuy
A Holley street dominator is nice. Those aren’t very tall and dyno well. Ive used them on mild stockish 383s with success. Don’t let the single plane scare you.
I want my fair share
[Re: parksr5]
#2434248
01/14/18 02:44 AM
01/14/18 02:44 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Performer RPM is hard to beat from all the dyno numbers that I've seen. I ran one on a mild 383 and a 470 stroker; worked good on both. This. Really good intake. The only one that made a little more power was the single plane M1 intake, which isn't made anymore.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
#2434338
01/14/18 12:00 PM
01/14/18 12:00 PM
RapidRobert
Any dual plane alum intake that you could source locally for cheap (CL is worth a try). As said the Performer single plane is an exception.
[Re: SomeCarGuy]
#2434350
01/14/18 12:22 PM
01/14/18 12:22 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
A Holley street dominator is nice. Those aren’t very tall and dyno well. Ive used them on mild stockish 383s with success. Don’t let the single plane scare you. I hated that intake on the street and I run 3:91 Gears Auto Trans Zero Torque from 0 - 3500 Rpms Was just a dog compared to the Performer I replaced it with Now above 5,000 Rpms , another story
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: BSB67]
#2434360
01/14/18 12:41 PM
01/14/18 12:41 PM
Posts: 889 Oh
parksr5
Oh
Mild 383, DP4B or a regular Performer. Would not recommend a single plane. The DP4B is what replaced the Performer RPM on my car. Hopefully I'll have some track numbers in the Spring for everyone.
#2434417
01/14/18 02:25 PM
01/14/18 02:25 PM
bee1971
Sobieski Wi
Read / Click On Link Above
383 Intake Manifold Comparison
#2205968 ..... {1963 thru 1967 Casting} .................... 14.17 ..... 98.04
#2951666-1 .. {late-1970 and 1971 Casting} .............. 14.06 ..... 99.43
#2806301 .... {1968 and 1969 Casting} ...................... 14.04 ..... 99.11
Edelbrock Performer {#2186} .................................... 14.01 ..... 99.58
Mopar M1 Dual-Plane {#4529117} ............................. 13.99 ..... 100.02
Weiand Action Plus {#8008} ...................................... 13.97 ..... 99.78
Edelbrock {DP-4B} ................................................... 13.93 ..... 100.12
#2434425
01/14/18 02:44 PM
01/14/18 02:44 PM
Posts: 4,441 Michigan
MarkZ
Worthy
Worthy
No love for the Torquer 383? Got one on my combo. Don't know how it would stack on a stock stroke motor though. Got mine off the board here for $120.
[Re: SomeCarGuy]
#2434459
01/14/18 03:33 PM
01/14/18 03:33 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
A Holley street dominator is nice. Those aren’t very tall and dyno well. Ive used them on mild stockish 383s with success. Don’t let the single plane scare you. Totally agree. Love that intake. Have it on my stockish 67 coronet with a 383. All it has is the street dominator intake, a little cam and a 750 dp carb. At 4025 lbs runs 15.00.
[Re: bee1971]
#2434500
01/14/18 05:15 PM
01/14/18 05:15 PM
Posts: 2,255 IL
furious70
IL
A Holley street dominator is nice. Those aren’t very tall and dyno well. Ive used them on mild stockish 383s with success. Don’t let the single plane scare you. I hated that intake on the street and I run 3:91 Gears Auto Trans Zero Torque from 0 - 3500 Rpms Was just a dog compared to the Performer I replaced it with Now above 5,000 Rpms , another story +1. I did back to back testing with stock intake and the holley with 3.91 gears in a 4200lbs car. Gutless would describe it. 3rd intake was rpm perf and it's great. I kept the holley in the event I build a b block stroker tho. Back in the day that 383 with a 750dp, headers and oem intake went 14.18 @ 98mph
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: bee1971]
#2434634
01/14/18 10:01 PM
01/14/18 10:01 PM
OhioMopar
Mt.Gilead, Ohio
Edelbrock {DP-4B} ................................................... 13.93 ..... 100.12 Why no Performer RPM?
[Re: forphorty]
#2434747
01/15/18 12:17 AM
01/15/18 12:17 AM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
The old Torker 383 is a decent intake that you can usually find used very cheap. I paid $75 for mine. Both the 383 and 440 Torkers pull strongly in the midrange. It is not a good choice if you are running a low stall torque converter. The Holley SD is a great intake but is also soft on the low end. Unless you are using a 3500 stall converter, one of the dual planes would be better. My vote for a mild (whatever that is)383, Performer RPM. http://www.hotrod.com/articles/hrdp-0712-mopar-intake-manifold-compare/ I used the 383 Torker on mine, 2" carb spacer and a 3310, still have it. Get that carb and timing right and it will work fine. DP4B or stock 68-69 if totally street and no gear.
[Re: moparsquid]
#2435144
01/15/18 07:10 PM
01/15/18 07:10 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
It's my understanding that a mild build with stock cast iron heads as the topic of this thread seems to indicate, the performance advantage of the Performer RPM intake may not be fully utilized until one moves up to aluminum heads. That said, pick the intake that will allow you to run at least a 3" x 14" inch air filter without a drop base and still have adequate hood clearance. If you cannot achieve this, any incremental gain with a taller intake might be compromised with your limited air filter choices. See Engine Master Air Filter Shootout: https://youtu.be/EkpsydS8JXI
