440 cuts out on hard excelleration #2416373
12/10/17 07:30 PM
12/10/17 07:30 PM
S.florida
Jupiter331 Offline OP
S.florida
440 electronic ignition occasionally shuts down for a few seconds on hard acceleration. As if you turned the ignition on and off for a second. Thinking it was electrical I replaced the coil. No difference. Replaced ignition switch no difference. Thinking possible fuel starvation put high volume fuel pump in. Still have the problem. Only thing left I can think of at this point is ignition module or distributor issues. Any suggestions would be great.
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416378
12/10/17 07:40 PM
12/10/17 07:40 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
The carb is adjusted correctly?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416383
12/10/17 07:48 PM
12/10/17 07:48 PM
Run it up to the same RPM in your driveway & mash the throttle & see if you have an immediate accel pump squirt/& of sufficient duration. there would not be the same (fuel) demand as on the road but it'd be a VG start especially to see how the AP is acting. & in your driveway with your light hooked up, floor it & see if it stops blinking. Holler back.
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416401
12/10/17 08:34 PM
12/10/17 08:34 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
A bad ground to one of the electrical components could act that way. I chased one of those for a bit a while ago...
Re: 440 cuts out on hard excelleration [Re: DarrenS] #2416409
12/10/17 09:16 PM
12/10/17 09:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
float level? fuel slosh? accelerator pump/lever adjustment? mechanical/vacuum advance?
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416431
12/10/17 09:53 PM
12/10/17 09:53 PM
S.florida
S.florida
It's vacuum advance. It's dissent do this all the time so it's hard to reproduce in the driveway but I will take your advise and check. As far as a ground goes....my amp gauge tends to jump around erratically at idle. Could be a bad ground effecting the ignition as well?
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416488
12/10/17 10:47 PM
12/10/17 10:47 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I'm with Dayclona in checking carb float level.
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416512
12/10/17 11:28 PM
12/10/17 11:28 PM
S.florida
S.florida
Will check it tomorrow and get back......thanks
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2416841
12/11/17 05:17 PM
12/11/17 05:17 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
hi vol mech fuel pump may not cure starvation ,
depends on restriction to, before , fuel bump.
you may still need an elect pusher at the tank !
Re: 440 cuts out on hard excelleration [Re: DarrenS] #2416846
12/11/17 05:23 PM
12/11/17 05:23 PM
Check the connections on all the slide on electrical connectors for corrosion scope
Higher RPM demands more current to fire the coil and ECU which can lead to high resistance connection going open like a switch turned off shock Higher heat from more current flow has more resistance scope
Something on the ignition side is going open when held at WOT under a load long enough to create this problem work shruggy
I've seen this before years ago on a race car that was stored inside from PA shruggy
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2418501
12/14/17 03:09 PM
12/14/17 03:09 PM
Pacific NW
cuda66318 Offline
cuda66318  Offline
Pacific NW
Sounds like you may be describing a tip in stumble? Which is generally caused by a lean condition, lean conditions can be caused by carburetion or timing events.
Basics of tuning any engine is always Ignition 1st then carburetion.
Once it catches again does it haul the mail?
What Ignition Box coil combo are you running?
Is this a Vacuum secondary or mechanical carb? (brand and Part Number?)
Initial timing?
Vacuum canister hooked up? Which port, constant or Ported?
What does the idle timing come up to at idle when you connect the Vacuum can to the carb/manifold?
What's the total timing in the motor with no Vac connected and at what RPM?
Cam duration at 50?
Compression ratio?
Rear end Gear?
727 Trans? What stall speed on the convertor?
Re: 440 cuts out on hard excelleration [Re: cuda66318] #2418591
12/14/17 06:38 PM
12/14/17 06:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had that issue once in one of my Chargers under hard acceleration once in a great while it would just cut out like you turned off the ignition. It turned out to be the bulkhead connector in the firewall. Engine torque must have pulled on the engine harness just enough to cause the issue. Once I figured it out pulled everything apart, cleaned all of the connections, dielectric greased all of the connections & put it back together. Been good ever since.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 440 cuts out on hard excelleration [Re: 6PKRTSE] #2418954
12/15/17 01:13 PM
12/15/17 01:13 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Fuel slosh as stated above. On hard acceleration gas in the front bowl will slam back toward the metering plate and vent tube. It will run up the vent tube and into the carb causing a massive bog, just like shutting the engine off for a second. Here's a pic of the cure, a hose connecting the front & rear tubes. This keeps the fuel from dumping into the primaries fixing your problem. Smart drag racers figured this out years ago.
Re: 440 cuts out on hard excelleration [Re: GODSCOUNTRY340] #2418962
12/15/17 01:27 PM
12/15/17 01:27 PM
^^^ & iirc you cut a notch in the hose at the top of the curve for venting.
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2418965
12/15/17 01:29 PM
12/15/17 01:29 PM
Yes, you can see the notch in the top of the hose.
Re: 440 cuts out on hard excelleration [Re: GODSCOUNTRY340] #2419022
12/15/17 03:02 PM
12/15/17 03:02 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
will that carb accept a baffle?
Re: 440 cuts out on hard excelleration [Re: Jupiter331] #2434053
01/13/18 08:08 PM
01/13/18 08:08 PM
orange city,FL
Demon340GSS Offline
Demon340GSS  Offline
orange city,FL
I agree with 6PKRTSE.. Please check the bulkhead connection at the Firewall First... Then Check your ECU...
My car did it at the track and another racer came over and we found the connection was poor and burnt.
I repaired it and on the next run my car screamed like never before.
I too changed everything you did.
Even tried different carbs, You name it.
Turned out to be simple connections at the bulkhead.
Many racers bypass the factory harness connectors and run a independent wire through.
Years later at the track a guy running a 4 speed Duster launched his car and it died. After getting it towed back I remembered what happened to me and went over and offered the advise.
He checked it and the chassis had flexed enough the wires where not touching!
repaired and it fired right up.
Before this he said it did the same as you described..
Just my input on this.
Of course check your ECU too...
Grant Eaton.
Owner of Original collector and restored original mopars from Mr Norms Grand Spaulding Dodge.
