Re: heard contradicting news about plastic timing chain gears?
[Re: Sport440]
#2433812
01/13/18 11:20 AM
01/13/18 11:20 AM
Guitar Jones
Car had 30K from the original owner, only about 3k a year. Second owner now put another 16k on the counter. New tires. Brakes all around were put on three years back, but he only drives it a few miles here and there. AC works. Body is straight. I will see . Also, what new car are we talking about maybe?? Apparently it's a closely guarded secret.
[Re: moparpollack]
#2433854
01/13/18 12:55 PM
01/13/18 12:55 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
If you only knew a guy with a tow truck that could haul it for you. He might...
'71 Duster '72 Challenger '17 Ram 1500
[Re: fullmetaljacket]
#2433856
01/13/18 12:57 PM
01/13/18 12:57 PM
RMCHRGR
Spahn Ranch
More door B bodies can be cool in a '70's TV cop show sorta way.
#2434023
01/13/18 06:46 PM
01/13/18 06:46 PM
crabman173
crabman173
I really think 4 doors are the next wave I remember when wagons and C Bods were donors and junkers but hey TTI makes headers for C Bods now so only matter of time until 4 Doors is all some can or want to afford You let me see a good one cheap and I will jump on it
#2435315
01/15/18 11:40 PM
01/15/18 11:40 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Did the nylon gears come in low deck 383's? When I was a teenager I had a 383 '69 Coronet. Constantly got towed home due to loss of oil pressure. I was told the oil pickup and/or oil passages were getting clogged with nylon pieces. Sold car and never opened the engine up to look.
[Re: ProSport]
#2435558
01/16/18 12:40 PM
01/16/18 12:40 PM
Posts: 19,479 north of coder
moparx
yep. 383's got 'em too. i have a set still on the shelf from a 15k, 69 engine that looks like new. that set was taken out when this particular engine was "day two'ed", headers, dp4b intake/780 holley, racer brown ssh25 cam, roller chain and re-curved distributor. my 66 charger had that set as well. it went by,by with ???k, so i replaced it with a 413. that inland shifter sucked. was replaced with a hurst comp+, but i quickly found out i can't shift for s**t. these were "back in the day" when these cars were almost new.
