repair TIPM module 2006 dodge ram #1329416
11/01/12 11:28 AM
11/01/12 11:28 AM
sw chicago
RAH Online content OP
RAH  Online Content OP
sw chicago
does anyone know of a repair shop the can repair or reflash printed circuit board TIPM 2006 dodge ram 2500 diesel. board has open circuit right turn signal please help
Re: repair TIPM module 2006 dodge ram [Re: RAH] #1329417
11/01/12 11:42 AM
11/01/12 11:42 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I beleve the dealer can reflash and there may be a kit that by-passes it on Gino's site. But I could be wrong.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: repair TIPM module 2006 dodge ram [Re: Savoy1964] #1329418
11/01/12 02:46 PM
11/01/12 02:46 PM
Northwest
Four40mopar Offline
Four40mopar  Offline
Northwest
The dealer can reflash the TIPM, but it will NOT fix an internal problem
Re: repair TIPM module 2006 dodge ram [Re: RAH] #1329419
11/01/12 04:59 PM
11/01/12 04:59 PM
Kansas
cascius Offline
cascius  Offline
Kansas
I've replaced a lot of those for stupid different reasons. 2006 was about the worst when it came to those causing issues. Last time I replaced one I think they were about $700 plus you have to have it programmed to your vehicle. Good luck on it.
Re: repair TIPM module 2006 dodge ram [Re: cascius] #1329420
11/01/12 07:02 PM
11/01/12 07:02 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
POS crap. dealer just quoted $900 for a new one and something like another $200 plus to install it and flash it for the truck.
...all because one high beam won't work. Yes, the 2006 Ram.
Gawd I love my old crap; what's a 4001 sealed beam worth? 5 bucks?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: repair TIPM module 2006 dodge ram [Re: cascius] #1329421
11/01/12 07:52 PM
11/01/12 07:52 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
You dont need to program it to the vehicle just disconnect the batter plug it in and reconnect, then turn the key on for a min before you start it.
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: repair TIPM module 2006 dodge ram [Re: sreinheimer] #1329422
11/01/12 07:59 PM
11/01/12 07:59 PM
Kansas
cascius Offline
cascius  Offline
Kansas
From what I've been told yes, it will start and move by doing that but you run the risk of some of the options on the vehicle not working properly. That is why they have to program it to the vehicle.
Re: repair TIPM module 2006 dodge ram [Re: cascius] #1329423
11/01/12 11:16 PM
11/01/12 11:16 PM
Lawton, MI
Headhunter22 Offline
Lawton, MI
'03 Ram - paid right around $700 to have repaired. Instead of a fuse....
Re: repair TIPM module 2006 dodge ram [Re: Headhunter22] #1329424
11/02/12 12:04 AM
11/02/12 12:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes you need to program it. The cluster and the TIPM store all the vehicle options and Mopar said if you replace one it will send the info to the other over the bus but it never works that way when I was doing them. Had to hook it up to the Dealer scanner/computer as it will get the info by the vin off the internet thru Mopar.
I tell you I had a Durango one day hit by lightening and it took out every computer and pressure switch on the truck. That was even more work to program since nothing on the truck had the vin stored in it. Ron
Re: repair TIPM module 2006 dodge ram [Re: RAH] #1329425
11/02/12 12:49 AM
11/02/12 12:49 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
If the board has an open circuit it is possible to do the repair yourself. I lost all running lights on my o2 Ram 1500 and it turned out to be a corroded portion of the board.
There is a very good writeup on how to perform this surgery on the dieseltruckresource forum at the links below.
I have alos included pics of the repair that I did on mine. I just used a dremmel tool to remove the the protective coating on the board. With a 10 watt soldering iron I "tinned" each side of the break. I then "tinned" a short length of wire bent at a 90 degree angle to give me something to hold on to and absorb any excess heat. just a quick dab on each end of the wire bridging the gap was all it took. I then clipped off the excess with (not shown in the pics) and reassembled the box. Its been working fine for about 3 weeks.
Part 1
http://www.dieseltruckresource.com/dev/showthread.php?t=222371
Part 2
http://www.dieseltruckresource.com/dev/showthread.php?t=222373
My pics
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: repair TIPM module 2006 dodge ram [Re: finadk] #2433077
01/11/18 10:16 PM
01/11/18 10:16 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Anyone replaced one of these lately, I am having issues with a '06 Dakota causing intermittent trans issues. I see aftermarket ones on the web from a bunch of sources other than the dealer
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
