Metallurgical engineers #2431875
01/09/18 10:32 PM
01/09/18 10:32 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
What all the problems of mig welding on an aftermarket steel, not cast, flywheel? Hardening, brittleness? Kinda doubt it would warp, but.. Submerged welding process would be better I guess.
Re: Metallurgical engineers [Re: cudaman1969] #2431958
01/10/18 12:15 AM
01/10/18 12:15 AM
IN
ahy Offline
ahy  Offline
IN
I would think cracks or thermal induced stress concentrations that could become cracks would be the issue. Where does it need welded? That may matter. Also cost... welding vs new flywheel?
Re: Metallurgical engineers [Re: cudaman1969] #2431968
01/10/18 12:22 AM
01/10/18 12:22 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just buy the proper flywheel, you been farting about with this one for weeks.
Don't be the exception.
Re: Metallurgical engineers [Re: Supercuda] #2432005
01/10/18 01:15 AM
01/10/18 01:15 AM
fredericksburg,va
fredericksburg,va
I normally don't ask questions, I just do it.
Anyway I got a new idea.
Heaven forbid anyone who welds something, doom and despair.
Re: Metallurgical engineers [Re: cudaman1969] #2432050
01/10/18 03:02 AM
01/10/18 03:02 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Welding on a flywheel? Well, first off I think you would have to know EXACTLY what steel grade you have. There are many versions of "steel". Secondly, all welding processes introduce stresses into the base metal. When a liquid metal solidifies it shrinks, thus the stresses. So IF you were able to identify the base metal AND you were able to get an applicable welding procedure, I would think you would have to stress relieve the flywheel after welding. And then contend with potential distortion.
PS, there is nothing magic about the sub arc process.
Re: Metallurgical engineers [Re: cudaman1969] #2432132
01/10/18 12:13 PM
01/10/18 12:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why are you trying to weld it and where are you welding?
- Stu Harmon
Re: Metallurgical engineers [Re: feets] #2432271
01/10/18 04:14 PM
01/10/18 04:14 PM
California
mickm Offline
mickm  Offline
California
Good lord, I would never, ever have contemplated the thought of welding a flywheel. That is based simply on intuition. Many things can and should be welded, (I just had a fair amount of welding done on my K frame, including the perch that holds the motor mount in place), but there are things that to me should not be repaired or welded. A flywheel is one of them.
Heating metal to welding point does change the crystalline structure of the material, to whatever degree. In some cases it is negotiable, in others not so. So essentially you now have a spinning object with considerable centripetal force and differing, uneven crystalline structure throughout, directly perpendicular to your feet and lower legs.
That is not based on any scientific investigation or knowledge on my part, but unless convinced otherwise, that is something i would never do!
Re: Metallurgical engineers [Re: cudaman1969] #2432281
01/10/18 04:27 PM
01/10/18 04:27 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Beside that you have a surface that will have a different hardness and will lead to clutch chatter quickly.
Re: Metallurgical engineers [Re: cudaman1969] #2432345
01/10/18 06:21 PM
01/10/18 06:21 PM
AndyF Offline
AndyF  Offline
You need to be more specific if you want an engineering answer. Lots of flexplates are weldments. A flywheel could be a welded assembly if the design was correct. TIG is probably better than MIG but it all depends what you are trying to do.
Re: Metallurgical engineers [Re: cudaman1969] #2432351
01/10/18 06:30 PM
01/10/18 06:30 PM
organ
maximum entropy Offline
organ
time for a new flywheel. if you MUST weld it, at least be sure to spend significantly more than a new flywheel would have cost...
Re: Metallurgical engineers [Re: cudaman1969] #2432367
01/10/18 07:06 PM
01/10/18 07:06 PM
fredericksburg,va
fredericksburg,va
Pretty much every torque converter is welded back together plus the starter ring is welded on.
Crankshafts are welded up everyday to put back in service, (I guess they glue that Mallory metal in), I could go on. So what I'm hearing is a spinning flywheel is more critical than a spinning t converter or driveshaft?
I'm sure I'll get another flywheel, don't have the time to tinker with it. Plus I don't think it fits that bell housing either, too deep. Would still like to hear from an expert on the subject. Is there one out there?
Re: Metallurgical engineers [Re: cudaman1969] #2432381
01/10/18 07:21 PM
01/10/18 07:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
HOLD ON GUYS!
What part of the flywheel needs welding? Did the starter ring come loose? Was a bolt hole damaged? Was it broken in half and he's trying to put it back together?
If it's not a deep fissure being welded on the surface of the flywheel it's likely okay to repair.
- Stu Harmon
Re: Metallurgical engineers [Re: cudaman1969] #2432382
01/10/18 07:22 PM
01/10/18 07:22 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
....Would still like to hear from an expert on the subject. Is there one out there?
I'll bet you a $20 bill that if you find an 'expert' they are going to ask the same basic question I did, what 'steel' do you have? Unless you know that no knowledgeable 'expert' is going to touch your question. I'm no 'expert' but I got into a lot of weld repair during 41 years in power plants, mostly successful some not so. I saw an 8" shaft on an ash pump crack completely through at a weld build up in the packing area. Reason? High carbon steel shaft and no stress relieving after welding. I hate to be critical but you still haven't indicated just what you are trying to do. As such, examples such as ring gears, convertor weights, and crankshaft journals may or may not be applicable as they aren't subject to the forces a flywheel is. As with a lot of things in life, it all depends.
Re: Metallurgical engineers [Re: cudaman1969] #2432385
01/10/18 07:26 PM
01/10/18 07:26 PM
dogdays Offline
dogdays  Offline
Reality: A new steel flywheel will cost you less than welding an old one.
Theory: If you wanted to resurface a steel, not cast iron, flywheel, it could be done by running a continuous bead from the ID to the OD of the wheel, then facing it off. That would give an even hardness across the surface and would probably work out well. That's the only way I'd say welding the working surface of a flywheel could be done with satisfactory result. You'd probably need a welding procedure for the particular type of steel from which the original flywheel was machined. It may need to be stress relieved or normalized or another post-weld heat process.
Comment: I agree that most of the hysterical responses you got were meaningless, except they all pointed to the fact that it is far easier to create a problem welding a flywheel than it is to do the job properly. Avoiding hard spots is one area of concern.
There is another problem that was hinted at and that is weldability. Not all steels are equally weldable. But they are many many times more weldable than cast iron.
Supposing this was a flywheel for a Stutz Bearcat, it'd probably pay to develop a weld procedure and have it properly performed. But the Stutz's wheel is probably cast iron so the issue is moot. For a more modern vehicle, it will most likely be better to buy a new steel flywheel.
R.
Re: Metallurgical engineers [Re: cudaman1969] #2432391
01/10/18 07:44 PM
01/10/18 07:44 PM
fredericksburg,va
fredericksburg,va
Ok, build up the outer edge 1/8 inch so the ring will fit. 3/8" wide. I have no idea what type of steel, whatever's common for an aftermarket blow proof wheel, sliced off of a bar is my guess.
I would add the weld would not be within 1-1/2" of the clutch face.
Re: Metallurgical engineers [Re: dogdays] #2432442
01/10/18 08:52 PM
01/10/18 08:52 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By dogdays
...I agree that most of the hysterical responses you got were meaningless, ....
I fail to see how pointing out legitimate potential pitfalls of a proposed course of action qualifies as "hysterical responses". But that's just me. shruggy
Re: Metallurgical engineers [Re: 6PakBee] #2432480
01/10/18 10:17 PM
01/10/18 10:17 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Yep, there is.
But he has a good memory. wave
Mo' Farts
Moderated by "tbagger".
Re: Metallurgical engineers [Re: Grizzly] #2432484
01/10/18 10:21 PM
01/10/18 10:21 PM
California
mickm Offline
mickm  Offline
California
Now THIS is what happens when you weld a flywheel, boys and girls, every single time!
So let that be a lesson to you, DON'T DO IT!!
Re: Metallurgical engineers [Re: mickm] #2432487
01/10/18 10:30 PM
01/10/18 10:30 PM
fredericksburg,va
fredericksburg,va
The first attempts of a planetary trans from what I remember, lost part of his foot.. Of course I won't use that much percentage of nitro on my street car.
I'll only listen to the ones who stayed at the Holiday Inn too.
Re: Metallurgical engineers [Re: cudaman1969] #2432733
01/11/18 10:21 AM
01/11/18 10:21 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I am curious, how did you get a mismatched flywheel and ring gear that is off by 1/4" on the OD?
