positive vale stem seal installation Q #2423504
12/25/17 12:30 PM
12/25/17 12:30 PM
RapidRobert Offline OP
EQ heads. seal guide metal nub OD machined to .534" for my inner springs. Found a set of "2 ring rubber" seals on the shelf & their ID is ~.461" measured with plastic HF calipers. I can fit one on the nub & it "feels" pretty tight/secure then I worked the valve stem up in it & it seemed "moderately" tight. Does it sound like I am OK here? the seals are EOK 125 & I googled them & got the "EOK" company but no listing for the EOK 125 that is cast/raised on the seal. should I superglue/epoxy em in place? & as far as fitment I obviously want em to stay in place & not too much or too little oil allowed to the stem. frequent replacement is a non issue. thank you for your time.
Re: positive vale stem seal installation Q [Re: RapidRobert] #2423521
12/25/17 12:56 PM
12/25/17 12:56 PM
moparx Offline
moparx  Offline
not an expert by any stretch of the imagination, but i wouldn't use any superglue/epoxy/jb weld stuff in that application. that's just me. will have to get a smarter person to answer your question. sorry.
beer
Re: positive vale stem seal installation Q [Re: moparx] #2423530
12/25/17 01:09 PM
12/25/17 01:09 PM
Oh I think you are dead on, as I have never heard of that either (which begs the Q, where did I come up with it!) but I have never done PC types & I want it trouble free. EDIT I am most worried that the stem to seal fit may be too tight as I dont know the app/dimentions for these seals as I dont want to starve the stem for oil but if there is enough splash in that area??? it might be a non issue but the similar seal description in the Goodsen catalogue made mention of metering an amt of oil.
Re: positive vale stem seal installation Q [Re: RapidRobert] #2423645
12/25/17 04:33 PM
12/25/17 04:33 PM
All those type seals are design to be fitted, pressed onto a certain size O.D. valve guide boss, they come in 3/8,11/32 and 5/16 guide sizes as well as miilmeter for the other type motors.they come in multiple inner I.D. also, .629,.530,500 and several different O.D. on the seals so they fit into the inner valve springs sizes. They usually have a plastic sleeve for installing them that goes over the keeper grooves so they don't get torn up.
I buy them from Goodson, maybe look there for yours scope
Good luck and Merry Christmas thumbs
Re: positive vale stem seal installation Q [Re: Cab_Burge] #2423671
12/25/17 05:41 PM
12/25/17 05:41 PM
Cab actually the page in Goodsens that has a pic of the three different types is where I saw that mine are the "2 piece ring and rubber". they appear to fit snug on the head steel nub & good reminder on the installation sleeve as I have seen that piece before & if I cannot find it I will use some scotch tape instead. I'm mostly worried that the valve stem may be too tight thru the seal ID hole & not let enough lube past. these seals do adequately clear the inner mini springs ID.
Re: positive vale stem seal installation Q [Re: RapidRobert] #2423777
12/25/17 11:28 PM
12/25/17 11:28 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I remember you were looking for 8mm stem seals in another thread. If you have machined guides and 8mm valves could you use something like this?
https://goodson.com/products/5710-valve-seals
Re: positive vale stem seal installation Q [Re: Dcuda69] #2423850
12/26/17 11:15 AM
12/26/17 11:15 AM
^^^ those are the right dimentions
Re: positive vale stem seal installation Q [Re: Dcuda69] #2432052
01/10/18 03:13 AM
01/10/18 03:13 AM
Originally Posted By Dcuda69
I remember you were looking for 8mm stem seals in another thread. If you have machined guides and 8mm valves could you use something like this? https://goodson.com/products/5710-valve-seals
Got em/mocked up/perfect fit. Dcuda thank you!
Re: positive vale stem seal installation Q [Re: RapidRobert] #2432231
01/10/18 03:32 PM
01/10/18 03:32 PM
I've had several complaints on those type Teflon seals, no more for me tsk
I've switch to the better Viton type now scope
Re: positive vale stem seal installation Q [Re: Cab_Burge] #2432236
01/10/18 03:36 PM
01/10/18 03:36 PM
Cab did they come apart or come up off the nub or get loose around the stem?
Re: positive vale stem seal installation Q [Re: RapidRobert] #2432327
01/10/18 05:52 PM
01/10/18 05:52 PM
They harden up and quit wiping the oil off of the stems is what my customers told me work
I had a set do that to me, oil running down the exhaust valve stems into the ports puke
The new viton seals have a steel body with soft rubber, maybe viton on the inside of the body to retain the seal on the guides, they work way better than those earlier Teflon ones like your picture shows up
Re: positive vale stem seal installation Q [Re: RapidRobert] #2432334
01/10/18 06:05 PM
01/10/18 06:05 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Why not go to your local auto parts store and get a set for any magnum sb? the factory seals work fine and save you money and time.
Re: positive vale stem seal installation Q [Re: J. Hammer] #2432400
01/10/18 07:58 PM
01/10/18 07:58 PM
^^^ that is an excellent idea & it didn't cross my mind (for some reason). I've heard (unfounded) rumors that I like to complicate things. I might go ahead & use these on the stock car cuz it will be limited run time & I dont want em to go to waste then go ahead & get a set of OE's per your suggestion for the mags on an upcoming DD. An particular year/eng I should ask for?
Re: positive vale stem seal installation Q [Re: RapidRobert] #2432423
01/10/18 08:27 PM
01/10/18 08:27 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
I just make sumthing up like 2000 ram 1500 2wd 5.9,but thats to help goober behind the counter. You could look them up and use the pn as well.
Re: positive vale stem seal installation Q [Re: RapidRobert] #2432426
01/10/18 08:30 PM
01/10/18 08:30 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
I haven't used those teflon seals since the 80's and they still suck I bet.
Re: positive vale stem seal installation Q [Re: J. Hammer] #2432508
01/10/18 10:57 PM
01/10/18 10:57 PM
What if they won't fit properly over his valve guides? Check that out first, Robert twocents scope
Re: positive vale stem seal installation Q [Re: Cab_Burge] #2432516
01/10/18 11:11 PM
01/10/18 11:11 PM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Read his post and turns out they fit.
Re: positive vale stem seal installation Q [Re: J. Hammer] #2432561
01/11/18 12:27 AM
01/11/18 12:27 AM
& I forgot something, on these EQ's the inner spring ID is .711" so on these or a similar head the std type umbrella seal OD would need to clear.
Re: positive vale stem seal installation Q [Re: RapidRobert] #2432638
01/11/18 02:40 AM
01/11/18 02:40 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
The factory seals are .675od.
Re: positive vale stem seal installation Q [Re: J. Hammer] #2432690
01/11/18 09:01 AM
01/11/18 09:01 AM
That will work, thank you brother.
