Sealing a 46RH (solenoid connector) #2432079
01/10/18 05:31 AM
01/10/18 05:31 AM
Washington State
70Duster440 Offline OP
Washington State
Son and I are finishing a major makeover on his ‘93 Dodge Cummins W250. We pulled the VB to install a new OD solenoid and Transgo TFOD kit. We had trouble dropping the VB out of the case and discovered someone had goobered the solenoid connector around the o-rings with a sealer that looks like brown Permatex 2 or aviation.
Is the use of sealer around the connector where it passes through the case normal? I would think they’d be installed ‘dry’.
Re: Sealing a 46RH (solenoid connector) [Re: 70Duster440] #2432122
01/10/18 11:52 AM
01/10/18 11:52 AM
Guitar Jones Offline
Not normal but hacks are everywhere. I use a little trans assembly grease on the o rings and slide it in. I have seen those connectors leak through the terminals though. Maybe they were trying to stop a persistent leak.
Re: Sealing a 46RH (solenoid connector) [Re: Guitar Jones] #2433193
01/12/18 02:07 AM
01/12/18 02:07 AM
Washington State
Washington State
Cool, thanks!
