will this topper fit my '65 D100 pickup? #2431872
01/09/18 10:29 PM
01/09/18 10:29 PM
RapidRobert Offline OP
It is from a '93 Dakota. Thank you for your time.
Re: will this topper fit my '65 D100 pickup? [Re: RapidRobert] #2431969
01/10/18 12:23 AM
01/10/18 12:23 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
long bed, short bed, fleet side, step side?
No one here is Kreskin
Don't be the exception.
Re: will this topper fit my '65 D100 pickup? [Re: Supercuda] #2431976
01/10/18 12:31 AM
01/10/18 12:31 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had a Dakota topper on my 62 Dodge short bed and had to add 2x4's on the rails as it was not quite wide enough. It worked fine front to back but not side to side. The gap was about 3/4" on each side and the 2-by's worked perfectly, there are probably better ways to do it but not cheaper! biggrin
JB Rhinehart, Realist
A-Body's RULE!
Re: will this topper fit my '65 D100 pickup? [Re: Rhinodart] #2432014
01/10/18 01:36 AM
01/10/18 01:36 AM
I ain't sure what the Dak topper came from but it was roughly ~63" side to side & my 65 is a long bed AFAIK (truck newbie) but for sure it ain't a crew cab (if they even had crew cabs in 65). Jimmy that would be good if 2x4's would solve it.
Re: will this topper fit my '65 D100 pickup? [Re: RapidRobert] #2432099
01/10/18 10:46 AM
01/10/18 10:46 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 62 short wide came off a crew cab 4x4 ex-Navy plane tug from the Great Lakes Naval Base. I am sure they still made crew cabs in 65. What a driver it must have been, slant six granny 4-speed with 4.88 gears... dino
A-Body's RULE!
Re: will this topper fit my '65 D100 pickup? [Re: Rhinodart] #2432201
01/10/18 02:39 PM
01/10/18 02:39 PM
Jimmy this is going to be a 440 with your hyd bell/granny 4 sp setup. pretty much just a DD/parts hauler/tow the trailer/stock car
Re: will this topper fit my '65 D100 pickup? [Re: RapidRobert] #2432388
01/10/18 07:32 PM
01/10/18 07:32 PM
dogdays Offline
dogdays  Offline
Probably not. That cool looking backwards rake rear window gets in the way, for one thing.
R.
Re: will this topper fit my '65 D100 pickup? [Re: dogdays] #2432571
01/11/18 12:38 AM
01/11/18 12:38 AM
we ain't hauled it over there yet but I got 63 & 3/4" across the pickup bed top inside edges tonight & previously the topper was ~63" outside to outside cuz it was on the grass/debris & we didn't get a straight line measure
