Ford builds its own "Dana 60" #2431693
01/09/18 05:16 PM
01/09/18 05:16 PM
dogdays Offline OP
dogdays  Offline OP
I was just out scouting limited slips and stumbled across a "Ford 9.75 inch" rear end. It sort of looks like a Dana 60 but isn't. It looks like a possible new source. It's what you find in an Expedition IRS, also.
Just thought I'd bring it up.....
R.
Re: Ford builds its own "Dana 60" [Re: dogdays] #2431730
01/09/18 06:41 PM
01/09/18 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's a Ford corporate 9.75" not same as a Dana 60. Dana 60 has 10 cover bolts, corporate has 12.
Re: Ford builds its own "Dana 60" [Re: John_Kunkel] #2431735
01/09/18 06:50 PM
01/09/18 06:50 PM
dogdays Offline OP
dogdays  Offline OP
That's why I put quotation marks around the name. It was a surprise to me that they are building their own rear end that pretty closely duplicates one that's already on the market. Probably economics.
I am wondering if anyone else has noticed them and if they had a high performance application like the other truck axle.
R.
Re: Ford builds its own "Dana 60" [Re: John_Kunkel] #2431741
01/09/18 06:55 PM
01/09/18 06:55 PM
How many bolts on the Ford 8.8 covers?
Re: Ford builds its own "Dana 60" [Re: Cab_Burge] #2431793
01/09/18 08:22 PM
01/09/18 08:22 PM
dogdays Offline OP
dogdays  Offline OP
Ten. The 8.8 is pretty easy, it's kind of square.
The 9.75 looks like this:
A Dana 60 cover is below it:
Re: Ford builds its own "Dana 60" [Re: dogdays] #2431821
01/09/18 09:13 PM
01/09/18 09:13 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
No reason to even look at it unless you're fooling around with a later model Ford truck. Plenty of other better choices.
Re: Ford builds its own "Dana 60" [Re: CMcAllister] #2431858
01/09/18 10:12 PM
01/09/18 10:12 PM
gregsdart Offline
gregsdart  Offline
Due to a lack of race parts for it?
Re: Ford builds its own "Dana 60" [Re: gregsdart] #2432024
01/10/18 01:53 AM
01/10/18 01:53 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't know what's available for it. Looks like nothing. Housings are supposed to be weak. Look like they are stupid heavy. Randy's shows some gear sets for it up to 5.13. The only yoke is a flange type. Axles are some queer 34 spline deal. No spools. Looks like parts are mostly year specific. With D60s and 9"s supported by the aftermarket, why even consider it?
Re: Ford builds its own "Dana 60" [Re: dogdays] #2432042
01/10/18 02:35 AM
01/10/18 02:35 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Since some version of the F-9" is used on big tire pro mod cars, what's the advantage to more weight, more power lost, and all new parts?
Boffin Emeritus
Re: Ford builds its own "Dana 60" [Re: dogdays] #2432116
01/10/18 11:43 AM
01/10/18 11:43 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Ford's been using a few different sizes of the sterling axles since the late '80s. I've had alot of guys argue with me that they are a dana 70.
Re: Ford builds its own "Dana 60" [Re: polyspheric] #2432124
01/10/18 11:55 AM
01/10/18 11:55 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Plus if you break something in a 9" most likely someone in the pits will have parts for it.
Re: Ford builds its own "Dana 60" [Re: dogdays] #2432298
01/10/18 04:43 PM
01/10/18 04:43 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
It's not a 70 or an 80. It's a Sterling and it's a smaller version of their 10.5 used in full size trucks. And it's basically useless if you don't have a Ford truck. If you get beyond what a good 9" can withstand, then there are options beyond that from Strange, MW and others.
Re: Ford builds its own "Dana 60" [Re: dogdays] #2433133
01/12/18 12:05 AM
01/12/18 12:05 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
the 9.25's dont seem like a very good axle, we have seen several fail in stock trucks that dident appear to be abused, the 8.8's in the same trucks we dont see any problems with. the 8.8 is a great axle with a huge aftermarket following and they are damn near the same width as an e body rearend(1" narrower) and most have 3.55, 3.73 or 410s from the factory, have rear discs with e brakes and most are limited slips, they are in pre 2000 ford exploders and my local LKQ has em for $60 on their holiday sales
