Early 2000's Rams #2430374
01/07/18 04:11 AM
01/07/18 04:11 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I bought a 2004 Ram 1500 , 5.7 / AT / 4wd a couple months ago and I love it . Can you guys list all the known issues / part failures that are common with these trucks ?
So far so good at 188K....but I have no history on the truck .
yes , all my blend doors are stripped.... wink
Re: Early 2000's Rams [Re: 493_DART] #2430382
01/07/18 05:01 AM
01/07/18 05:01 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
In this town, rust over rear wheel openings.
Re: Early 2000's Rams [Re: 493_DART] #2430593
01/07/18 05:08 PM
01/07/18 05:08 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
If quad cab the wire harness pass through in the rear doors @ B pillars will fail. Sunvisors will droop and fail unless someone has already replaced them with the updated ones. Plastic cap on the top of the dashboard will be brittle and crack into a million pieces (if not already) when you touch it.
Re: Early 2000's Rams [Re: buildanother] #2430676
01/07/18 07:56 PM
01/07/18 07:56 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
oh yea...its got that
Re: Early 2000's Rams [Re: 493_DART] #2431452
01/09/18 02:44 AM
01/09/18 02:44 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
There was an airbag recall. Possibly a recall to make the horn blow when you open the door while backing up (don't get that). I think there may have been a rear axle issue, but that may be 2005?
Re: Early 2000's Rams [Re: 493_DART] #2431470
01/09/18 04:06 AM
01/09/18 04:06 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
you know....my rear diff cover is painted red...i thought that was odd......factory or a replacement ?
Re: Early 2000's Rams [Re: 493_DART] #2431519
01/09/18 10:54 AM
01/09/18 10:54 AM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
doors in the heater box (blend door, defrost, panel, floor) will break. the servo motors will snap them. Like you said. there is a kit where you cut into the heater box and replace them without removing the heater box.
Re: Early 2000's Rams [Re: 493_DART] #2431878
01/09/18 10:34 PM
01/09/18 10:34 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Re: Early 2000's Rams [Re: 493_DART] #2432676
01/11/18 06:04 AM
01/11/18 06:04 AM
GA, USA
U
ulrich Offline
ulrich  Offline
U
GA, USA
Good reference Dart, thanks!
Re: Early 2000's Rams [Re: 493_DART] #2433018
01/11/18 09:03 PM
01/11/18 09:03 PM
UP
finn Offline
finn  Offline
UP
My 05 had the cab harness ps hose, and water pump replaced under warranty.
Post warranty repairs are mainly rust related. Ps cooler rotted out, steel tube that supports the plastic grill rotted, tailgate is shot along the bottom seam and about three inches up across the entire width, left box wheel opening is toast. Will need a new box side.
Other: two egr valves, both front unit bearings, parking brake lining debonded, a couple sets of front rotors and pads, one set of rear rotors and pads. Both air bags and the pinion nut retorque recall were done also. One set of tires and a battery, and a dozen or so sets of wiper blades.
There is a front driveline vibration at 55 that needs attention. Dealer says the boot retainer clip rots and lets salt into the splines. An hour labor and a clip and o ring fix the problem, unless the splines are too far gone.
It’s 13 years old in a couple of weeks, and has 111k miles.
Re: Early 2000's Rams [Re: finn] #2433987
01/13/18 05:39 PM
01/13/18 05:39 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
My list is similar, but add:
rear driveshaft u-joints
rear diff cover replaced due to rust
rear diff pinion seal- changed without disassembling the rearend
power window switches - both sides
exhaust heat shield on passenger side has rusted off
lower idler pulley disintegrated - was able to limp it home
starter - the exposed copper portion corroded and failed
rack and pinion under warranty in addition to p/s hoses
blend door - always blowing out defrost in addition to other selections
power distribution box underhood has a failed circuit internally - taillights/front parking lights are manually operated with a toggle switch. Have been too lazy to wire up a relay and the replacement box is ~$400.
