Help Tracking Down a GM typeII power steering pump #2431028
01/08/18 01:42 PM
01/08/18 01:42 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have this Speedway pump on my Hemi and could use some help investigating what it’s original application might be for. The pump has 1,500 miles and whines like crazy, Speedway offers no warranty so I’d like to find it local so I can have a warranty.
https://www.speedwaymotors.com/Aluminum-Power-Steering-Pumps-w-Reservoir,12707.html
What I know
Manufacturer: Maval
Type: GM Type II
Output: “low pressure”, 2GPM
Shaft OD: 0.659”
Outlet: 16mm-1.5 oring
Inlet: 3/8” barb
I believe it would have come on a common fwd GM product, but I need to be able to identify one as “low flow”.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2431040
01/08/18 02:01 PM
01/08/18 02:01 PM
Andrewh Online content
Andrewh  Online Content
according to the link, low flow is a ford application.
you could check the part number against mavin's website.
My guess is
https://www.partsology.com/dnj-power-ste...1AaAuXmEALw_wcB
without the resevior.
http://www.mavalgear.com/index.php?optio...&Itemid=322
Grand Marquis. 1992
Mercury. Colony Park/Grand Marquis. 1992, 1993, 1994, 1995, 1996, 1997, 1998. w/8 Cyl Eng,
but that is a guess without some further research or if you can pull a part number off of it.
your link won't give one as far as I can tell.
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2431095
01/08/18 03:30 PM
01/08/18 03:30 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
What about jeep? Is the flow difference rack and pinion vs steering box?
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2431097
01/08/18 03:32 PM
01/08/18 03:32 PM
I would think that doesn't matter, as I am using a rack pump from a 2000 durango in my 65 coronet with the box.
I think Goody is using the borgsomething or other box which may have some specific pump needs.
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2431188
01/08/18 07:04 PM
01/08/18 07:04 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I have the boreson box and part of me wants to try the jeep pump. I don't really want to put another Saginaw in and have it not be any better than what I have now.
Re: Help Tracking Down a GM typeII power steering pump [Re: JAMESDART] #2431252
01/08/18 08:53 PM
01/08/18 08:53 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Chevy Cavalier I believe, as well as various other GM.
I have a type 2 on my car, it whines also.
When you lower the flow and pressure for a Ford rack causes the problem based on my experience
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Help Tracking Down a GM typeII power steering pump [Re: 6bblFLASH] #2431320
01/08/18 10:42 PM
01/08/18 10:42 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks Andrew. Yes, I have a Borgeson box, but it doesn't really require any different pressures, from what I have read. Perhaps I need the high flow pump and the low flow just doesn't cut it. [?]
Thanks, i'll check into that.
2020 RAM 1500
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2431335
01/08/18 11:07 PM
01/08/18 11:07 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
The jeep pump is listed as 2.4-2.8 gpm, 1350-1450 psi.
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2431732
01/09/18 06:45 PM
01/09/18 06:45 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you want it in aluminum or steel?
I thought the aluminum ones are certain applications. Sorry I don't have applications, but I've heard FWIW Corvettes have aluminum versions.
Re: Help Tracking Down a GM typeII power steering pump [Re: 6bblFLASH] #2432164
01/10/18 01:25 PM
01/10/18 01:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The PS pump whine is really common on Mercedes cars, too. Luckily, you don't hear it while driving.
I'm interested in doing the serp belt conversion on the Imperial and would like to find a whine-free pump for it.
- Stu Harmon
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2432306
01/10/18 05:01 PM
01/10/18 05:01 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
How did it work with that type2 pump?
I was looking at corvette pumps the other day but the ones I saw were for remote reservoir. Im really tempted to try the jeep pump. I had a spare one here but I think I threw it out or something.
What is the borgeson box core? When I put mine in I didn't want to pay a fortune for a hose or adapters. So I looked around on rock auto and found an application with the same looking box. I then found a hose from some of those applications, and for like 10$ I had that hose crimped onto the end of the mopar pump hard line.
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2432769
01/11/18 12:57 PM
01/11/18 12:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The whine is usually from sucking air into the fluid. Very few problems with that style pump when I worked at the dealer. What does the fluid resivoir look like? Is it clear or does it have small air bubbles in it? You can make up a modified cap and vacuum the system. This will draw the air out over a period of time.
Doug
Re: Help Tracking Down a GM typeII power steering pump [Re: dvw] #2432772
01/11/18 01:03 PM
01/11/18 01:03 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Doug
I am thinking this may be part of the problem. It doesn’t look as clear as I’d like
The reservoir fluid level is also lower than the high pressure line outlet. When these pumps are setup with an AN adapter and an AN 90° fitting, that line gets pretty high relative to the proper fluid level. Perhaps that isn’t helping with aeration.
I like the idea of vacuum on the cap. I’ll need to think on a solution for that.
2020 RAM 1500
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2459200
03/01/18 12:58 AM
03/01/18 12:58 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Riddle me this, Moparts.
Problem: Pump has a constant whine under any load. No air present in the fluid, it's plenty full, low-mile pump.
Finding: Reservoir Cap Not Vented. I gave in and ordered a new pump. Upon disassembly I found that despite there being a vent hole in the cap, the reservoir does not vent. That being said, I believe the fluid in my reservoir is only slightly entering the pump, or the pump is essentially having to suck for it's feed [bad]. This problem may be amplified since this style of pump is more of a side-feed from the reservoir, rather than a top feed [shown]
I can't drive the car for a few days to find out if this is going to be helpful or not.
Venting solution: I did notice that the two small holes on the underside of the cap [one shown] were not talking to the vent hole in the top. Very slight drilling opened them up to vent...perhaps I am on to something? What do you think?
[video:youtube]https://youtu.be/ZD2a0gK08_Y[/video]
2020 RAM 1500
Re: Help Tracking Down a GM typeII power steering pump [Re: GoodysGotaCuda] #2459230
03/01/18 02:26 AM
03/01/18 02:26 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we use the jeep pumps and have been using them for years in our serpentine belt kits.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Help Tracking Down a GM typeII power steering pump [Re: Jerry] #3172017
09/01/23 09:28 AM
09/01/23 09:28 AM
PENNSYLVANIA
E
EARLY B Offline
EARLY B  Offline
E
PENNSYLVANIA
i
I know this is a old post. Did anyone resolve the noise issue with there pump?
Re: Help Tracking Down a GM typeII power steering pump [Re: EARLY B] #3172035
09/01/23 10:51 AM
09/01/23 10:51 AM
AndyF Offline
AndyF  Offline
I've had a Type II pump in my Coronet for years and it doesn't whine or make any odd noises.
