Anyone here running a 340 Abody with W2 heads & TTI headers?
#2430697
01/07/18 08:53 PM
01/07/18 08:53 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I Have a 71 340 4 speed Demon, stock block, engine mounts, bell housing, and transmission. It was a running driving car when I bought it but the clutch was getting tired. Not many miles on it, under 1,000, probably far less but previous owner drove the wheels off of it so a worn clutch is no surprise. So I decided to change out the clutch this week, same style McCloud clutch, all new stuff.
When I disassembled the old stuff I noticed that the adjuster rod nut was only a few threads away from the un-threaded part of the rod. When I installed all of the new parts I had the same issue, only a few threads showing between the smooth end of the rod and the nut before the TO bearing started making contact with the fingers.
There has to be a simple fix to this? Maybe a B-body adjuster rod? A different Z-bar?
The previous owner said he had to modify the Z-bar for clearance per TTI's instructions but he doesn't recall exactly what was modified.
Any help appreciated
Re: Anyone here running a 340 Abody with W2 heads & TTI headers?
[Re: ScottSmith_Harms]
#2430736
01/07/18 09:43 PM
01/07/18 09:43 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
Scott, i'm using the stock fork in a scattershield. The nut on mine is near the end of the threaded part of the rod. I had to shorten the arm on the bellcrank that the adjustment rod attaches to with the TTI's. I have a mccloud borg and beck pressure plate. My adjuster rod appears to be different (shorter).
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
#2430741
01/07/18 09:50 PM
01/07/18 09:50 PM
moparfan
Marysville Wa
I just went and looked at it. It looks like I shortened the adjusting rod. I cut the rod and put both ends inside of a piece of tubing and welded it back together after I got it the right length.
#2430828
01/07/18 11:53 PM
01/07/18 11:53 PM
moparfan
Marysville Wa
mine is angled on the front as well. I didn't clock the arm differently, just shortened it. Just putting the 4 speed back in the car, Had a 904 behind this engine. Looks like It should work
