roll the dice and come up craps #2428803
01/04/18 12:29 PM
01/04/18 12:29 PM
scratchnfotraction Offline OP
ouch! missed 1 PR and wiped the cam/lifter on fire up. that's what getting in a hurry does for ya.
Re: roll the dice and come up craps [Re: scratchnfotraction] #2428816
01/04/18 12:46 PM
01/04/18 12:46 PM
so back up and regroup roll the dice one more time..
found a new reman 318 never fired in a JY for 100$ no warranty.
VC/intake was off and had a little rust showing a little water had been in there. none in the cyls/ports but filled oil pan just under the crank rod bolts.
replaced oil pan/pump/tube removed the new flat tappet cam/lifters and installed a stock roller cam and lifters after flushing/cleaning everything up. couple cans of dupli-color black and it all back to stock.
on install I correct the engine mounts to get the trans mount bolted up correctly (to far forward) got the mounts set, replaced old for new driveshaft and balance.
fired up and adjusted timing/carb and it runs nice and smooth.
while I had the front clip off I washed prepped primed painted it.
spent a day in the u-pull it collecting all the fender bolts and jesus clips to replace what I had on there. about 10 bolts holding it together.. replaced all for a total of 32 bolts/clips that should fix most of the rattle noise up front.
going with the 2013 Dodge Dart R/T "citrus peel pearl" & black
Re: roll the dice and come up craps [Re: scratchnfotraction] #2428921
01/04/18 03:29 PM
01/04/18 03:29 PM
Guitar Jones Offline
Nice score!
Re: roll the dice and come up craps [Re: scratchnfotraction] #2429029
01/04/18 06:44 PM
01/04/18 06:44 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
so what's this going in Mike? The stepside or something new?
1981 Dodge D150 360 auto
Re: roll the dice and come up craps [Re: scratchnfotraction] #2429219
01/04/18 10:45 PM
01/04/18 10:45 PM
giving the stepside some luv
Re: roll the dice and come up craps [Re: scratchnfotraction] #2429423
01/05/18 01:24 PM
01/05/18 01:24 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
That'll look really nice on a truck (had to look it up). Looking forward to seeing it in paint.
Re: roll the dice and come up craps [Re: scratchnfotraction] #2429480
01/05/18 04:04 PM
01/05/18 04:04 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I'm tickled the second "roll" was good. You certainly deserve a break! Man, that lifter didn't rotate at all!
Re: roll the dice and come up craps [Re: scratchnfotraction] #2429642
01/05/18 09:53 PM
01/05/18 09:53 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Yes he does deserve a break. Good guy.
Keep on truckin Mike grin
Facts are stubborn things.
Re: roll the dice and come up craps [Re: larrymopar360] #2429659
01/05/18 10:30 PM
01/05/18 10:30 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
True 'dat!
Re: roll the dice and come up craps [Re: scratchnfotraction] #2429848
01/06/18 11:56 AM
01/06/18 11:56 AM
E
earlymopar Offline
earlymopar  Offline
E
"PR"?
Re: roll the dice and come up craps [Re: earlymopar] #2429979
01/06/18 03:09 PM
01/06/18 03:09 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Originally Posted By earlymopar
"PR"?
I was wondering the same.
Re: roll the dice and come up craps [Re: scratchnfotraction] #2430135
01/06/18 08:00 PM
01/06/18 08:00 PM
Wisconsin USA
themoparmanjc Offline
Wisconsin USA
I’m assuming it stands for pushrod
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: roll the dice and come up craps [Re: scratchnfotraction] #2430189
01/06/18 09:42 PM
01/06/18 09:42 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I kept thinking piston ring that didn't explain the damage.
Re: roll the dice and come up craps [Re: scratchnfotraction] #2430419
01/07/18 11:43 AM
01/07/18 11:43 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Keep the updates comin! Got nuttin to do in negative temperatures. snowblow
Re: roll the dice and come up craps [Re: scratchnfotraction] #2430973
01/08/18 11:46 AM
01/08/18 11:46 AM
Thanks guys. 2016 has been a long ruff year for the wife and I. lower & upper back problems make it hard to keep wrenching by myself. I had 2 weeks winter break and worked 10 days out of 14 to get a fresher engine and paint the front clip/doors. ran out of time and $$ doors are waiting for warmer weather here in Fl. computer and phone issues are making thing difficult to post my pics. been trying 3 days to get pics with the front clip painted. I gots me a dumb phne for sure.
yes, PR = push rod = was out off the rocker pocket holding the exhaust valve open. got a small eyebrow on the piston and will need to go over the heads again.
LARRY = that was the police engine I got from you. got in a hurry and missed the back PR on driver side. but it is back on the stand and already flushed and going back together with the whiplash roller cam. redoing the 360 heads just to sleep at night know no bent/sticking valves.
funny how I NOW remember how whimpy a stock 318 cam is and how much a mild cam/intake/headers do for a 318.
I hoping to roll the dice in March on spring break if I have the police engine converted and back together ready to go.
Re: roll the dice and come up craps [Re: scratchnfotraction] #2431169
01/08/18 06:07 PM
01/08/18 06:07 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Hope your back is better soon. The warmer weather past couple of days has been nice but now we have rain, at least down this way. Hope you can hit your March goal up
Larry
