1970 340 Duster wiring harness issue #2429554
01/05/18 06:42 PM
01/05/18 06:42 PM
Colorado
CuriousYella70 Offline OP
Colorado
I'm replacing my original 340 rallye harness with a new one from Year One because it's old, rotting and just not safe. When putting in new fuses to the fuse box, I noticed there's no fuse connector to the AAC section but on my original harness, there is but no wire attached to it. Is this normal? What is the AAC fuse section for?
Thanks!!
received_10100601894231661.jpegreceived_10100601894406311.jpegreceived_10100601894476171.jpeg
Re: 1970 340 Duster wiring harness issue [Re: CuriousYella70] #2429576
01/05/18 07:17 PM
01/05/18 07:17 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That would be an acc powered outlet for an option you car does not have. Think an AC compressor, or rear defroster, or power windows or heated seats (should you decide you need them) power source.
In the original harness, Mopar supplied the terminal to connect a wire to, the aftermarket harness would need the fuse holder end and the wire to the accessory. Gene
Re: 1970 340 Duster wiring harness issue [Re: CuriousYella70] #2429598
01/05/18 08:08 PM
01/05/18 08:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
you could look in the wiring diagrams and find out.
http://www.mymopar.com/index.php?pid=109
Don't be the exception.
Re: 1970 340 Duster wiring harness issue [Re: CuriousYella70] #2429612
01/05/18 08:36 PM
01/05/18 08:36 PM
Colorado
Colorado
Thanks guys!! Definitely appreciate the fast response!
Re: 1970 340 Duster wiring harness issue [Re: CuriousYella70] #2429615
01/05/18 08:42 PM
01/05/18 08:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
ACC, any accessory not installed on car
