Page 2 of 4 1 2 3 4
Re: New Trick Flow heads for Ford FE [Re: CompWedgeEngines] #2425996
12/30/17 06:16 PM
12/30/17 06:16 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By CompWedgeEngines
I grew up working on FE Fords, I still do some BBF engines.Ford FE series engines, are literally among some of the biggest movers right now for some of the manufatures parts...its scary how many are being built right now. Cheap, easy to find, and decent bang for the buck.460 BBF is same, easy to make great power and torque, and parts ARE available.
The FE is a cool looking engine with the pentroof valve covers and the wild intake and exhaust manifolds. It is a quirky engine with the pushrods in the intake and stuff like that but I guess that adds character. Some of the stuff is similar to a BB Mopar. Shaft rocker arms, front oil pump, skirted block, cross bolted blocks on the race engines, etc.
Re: New Trick Flow heads for Ford FE [Re: Spaceman Spiff] #2425997
12/30/17 06:19 PM
12/30/17 06:19 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By Spaceman Spiff
Originally Posted By sgcuda
Do you foresee any problems with the slightly longer, taller runners on the rear cylinders like that? What's the deal with the center ridge in the floor of the intake port in the cylinder head?
i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines.
The ridge in the intake port is for flow. They call it a floor wing or a vane. It sits in the low velocity part of the port and helps the mixture make the turn into the valve. At least that is the theory. I suppose Trick Flow did a bunch of flow bench development with and without the wing but they didn't post any of that information on their website so I'm just guessing that they found that it helps. I don't think I've seen a wing like that in any Mopar ports but I've seen it before in some Chevy engines.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2426024
12/30/17 07:32 PM
12/30/17 07:32 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Jay Brown is now selling these intake adapters for FE Ford engines. They adapt a 351 Cleveland intake to it. So you have more manifold choices, and you can swap intakes or inspect the valley without draining the coolant and disassembling the valve train. They are selling like hotcakes.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: New Trick Flow heads for Ford FE [Re: Hemi_Joel] #2426026
12/30/17 07:39 PM
12/30/17 07:39 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Wow: Now that is a piece that makes a lot of sense.
Sheldon
Re: New Trick Flow heads for Ford FE [Re: RUNCHARGER] #2426056
12/30/17 08:54 PM
12/30/17 08:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I race with a bunch of FE ford guys when I meet with the UMTR stick guys.
Larry's wagon is a cool FE racer up
Gus beer
64 Plymouth Savoy
Dana 60
Re: New Trick Flow heads for Ford FE [Re: fourgearsavoy] #2426090
12/30/17 09:52 PM
12/30/17 09:52 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
A friend / customer of mine was looking for a replacement 427 side oiler block a few years ago. I was surprised when he showed me what he had found in an old box ! shock
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: New Trick Flow heads for Ford FE [Re: Hemi_Joel] #2426107
12/30/17 10:24 PM
12/30/17 10:24 PM
AndyF Offline OP
AndyF  Offline OP
Yeah that setup does make some sense for the serious FE guy. The bottom part seals up the engine and leaves the intake dry. So then you can swap intakes in just a few minutes like on a BB Mopar. With the factory setup pulling the intake off is fairly major surgery. You have to pull the rocker shafts and the pushrods and drain the water and so on. Really a big time bother.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2426122
12/30/17 11:07 PM
12/30/17 11:07 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
That tunnel ram is a sweet looking piece!!!!
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2426281
12/31/17 12:19 PM
12/31/17 12:19 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I noticed a bid difference in flow swirl pattern on the piston with a tilted port floor on my iron heads from the Edl flat port I have .
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2428855
01/04/18 12:21 PM
01/04/18 12:21 PM
AndyF Offline OP
AndyF  Offline OP
Engine is almost together, just trying to round up the correct intake gasket at the moment. Once we have the correct gasket the top end should fall together quickly.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2428869
01/04/18 12:46 PM
01/04/18 12:46 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think I see oil drain holes in the corner of the heads,Is that correct.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2428871
01/04/18 12:56 PM
01/04/18 12:56 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
[/quote]
i think that ridge is for pushrod tube clearance. Pushrods go through the intake on FE engines. [/quote]
That intake in the picture is NOT a tunnel wedge. My buddy has a set of those and the ports are as big as baseballs with a tube right thru the middle of them on the intake side. The heads are also very large with no tube restrictions. He said they do not really run that well because of the airflow restrictions from the big pushrod tubes.
This is still a very nice looking set up. [/quote]
The intake we're using is a tunnel wedge. The intake you are talking about is a tunnel port. [/quote]
My bad Andy.
You are correct about it being a tunnel wedge. My typo as i was trying to clear up the statement "the push rods do not go thru the intake port" on those heads or intake. I should have said tunnel port intake.
Thanks for sharing this post. Sometimes it is fun to see what other brands have available with out going to Yellow Bullet.
Old Geezer Racing
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2428873
01/04/18 12:59 PM
01/04/18 12:59 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I can see how the floor vane would direct airflow and create a swirl effect. Would this improve on the low end power, OR the Mid range or top end?
Old Geezer Racing
Re: New Trick Flow heads for Ford FE [Re: SCATPACK 1] #2428883
01/04/18 01:32 PM
01/04/18 01:32 PM
AndyF Offline OP
AndyF  Offline OP
That is my guess but I really don't know. I asked Trick Flow for an explanation on the floor wing but they didn't reply to my email. Which is weird since they sent me the heads for testing.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2429313
01/05/18 01:49 AM
01/05/18 01:49 AM
Utah, USA
1964superstock Offline
Utah, USA
Ford-Edsel (FE) Motor. Leave it to Ford to over complicate everything like the FE intake manifold design. Deck the block or mill the heads, and headaches are yours fitting those intakes. Very cool trick flow is making great heads for old Chrysler and Ford engines. Makes getting good horsepower easy.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2429411
01/05/18 11:54 AM
01/05/18 11:54 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Those long exhaust ports are a heat soak, great place for Swain coating.
Boffin Emeritus
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2429427
01/05/18 12:48 PM
01/05/18 12:48 PM
AndyF Offline OP
AndyF  Offline OP
I agree, the FE head design is very, very weird. But it is weird in a cool way which is probably why these engines are so popular. I've looked at other engines of the era and they are weird in a stupid way which is why they aren't popular anymore. Some of the older BOP designs for example or older Caddy engines have some super odd stuff going on. Integral bellhousings, decks at odd angles, etc.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2429507
01/05/18 03:53 PM
01/05/18 03:53 PM
Cab_Burge Online work
Cab_Burge  Online Work
The ridge in the intake port is for flow. They call it a floor wing or a vane. It sits in the low velocity part of the port and helps the mixture make the turn into the valve. At least that is the theory. I suppose Trick Flow did a bunch of flow bench development with and without the wing but they didn't post any of that information on their website so I'm just guessing that they found that it helps. I don't think I've seen a wing like that in any Mopar ports but I've seen it before in some Chevy engines. [/quote]
I seem to remember a article in one of the drag magazines years ago about adding dams in the intake manifolds intake ports to aid airflow, I guess it didn't catch on back then confused
I had a hemi motor that had been built by Petty Ent. for a clone NASCAR 1967 Plymouth of Marty Robbins car, it had the big two piece single Dominator flange bathtub NASCAR intake with a bunch of air dams and ridges cut into the floor.
That intake had the best fuel distribution as far as the EGT reading(all within 25 F from part throttle loaded at 1300 RPM to WOT) of any motor I've dyno tested up
Ford had so many variations of the FE race heads it ain't even funny haha
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2433608
01/12/18 08:38 PM
01/12/18 08:38 PM
AndyF Offline OP
AndyF  Offline OP
Here is a link to the first article on these heads: http://www.hotrod.com/articles/new-product-overview-ford-fe-heads-trick-flow/
We're still waiting for the correct intake gasket before the engine can be fired up. Should be anytime now.
Re: New Trick Flow heads for Ford FE [Re: AndyF] #2434394
01/14/18 12:42 PM
01/14/18 12:42 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I admire engines that are not common/mainstream. FE, Desoto Hemi, Nailhead, 409, Wildcat...Polysphere. Not economical to build by any means but many owners are not pinching pennies when paying to have their project built.
Keep old mopars alive.
Page 2 of 4 1 2 3 4
