1970 383hp fuel pump fitting question #242860
03/04/09 01:36 PM
03/04/09 01:36 PM
California
70SportSatellite Offline OP
super street
super street
California
in the 440 post i see it has a threaded fitting for the outlet and a nipple for the inlet. On a factory installed 383 fuel pump is it the same? I have heard it is but the replacement uses a hose nipple for the outlet. I've tried looking at old manuals and I see where this might be possible. thanks
Re: 1970 383hp fuel pump fitting question [Re: 70SportSatellite] #242861
03/04/09 02:24 PM
03/04/09 02:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes it's the same , the nipple pump is the 383 2 bbl
Re: 1970 383hp fuel pump fitting question [Re: JohnRR] #242862
03/05/09 04:12 PM
03/05/09 04:12 PM
GeeTeeX Offline
GeeTeeX  Offline
Hey 70, that's exactly the problem I ran into. All the aftermarket part information available for a stock fuel pump all show the two nipple pump for a 383 and 440. It'll work if you want to redo the fuel outlet line with a rubber hose to fuel vapor separator but make sure the belts don't make contact and rub through the hose....
Re: 1970 383hp fuel pump fitting question [Re: GeeTeeX] #242863
03/05/09 07:35 PM
03/05/09 07:35 PM
California
super street
super street
California
What I ended up doing was finding and purchasing a 440 pump with the outlet fitting for tube but the inlet is a 3/8 nipple and the tank line is 5/16. I don't know if it's accurate since the fittings are parallel to each other. I think the OE fittings may be pointed away from each other like one on EBay right now claiming to be correct for $200.00. (pic attached)
Are 440-4 3/8? or just 440-6? Anyway,I'm OK with the one I have since it was less than half the price. I was able to stretch the hose onto the 3/8 nipple and used a 3/8 Keystone clamp.
Re: 1970 383hp fuel pump fitting question [Re: 70SportSatellite] #242864
03/06/09 12:02 AM
03/06/09 12:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
440 had a 3/8 line , both 4 bbl and 6 bbl
